    Return values
    14 Posts 3 Posters 1.5k Views 3 Watching
      prompts = ["Width mm", "Breadth mm", "Height mm"] defaults = ["100", "100", "100"]
      Let SketchUp handle the units for you. If you feed the input box Length objects as defaults - it converts the user input to Length's for you.
      defaults = [100.mm, 100.mm, 100.mm]
      It's better to work with units in SketchUp's units - internally inches - and always ensure you have Length objects when you output to the user. That way the user gets the units in his/her preferred unit and you don't have to do a thing.
      • Dan RathbunD
        Dan Rathbun
        There was another topic on this issue, I think I may have posted a method in there.
        Or.. hmmm... It may have a "[Code]" prefix in the title.
        ADD: found it: Volume of Multiple Groups
        You might get some ideas from that, and there is a link to one of TIG's old utilities.
        Anyway.. TT... One thing you or TIG have not done yet is a "Units: The Lost Manual" πŸ˜†
        I'm not here much anymore.
          That is in fact on my list to write up.
          • Dan RathbunD
            Dan Rathbun
            @paulg said:
            Thanks Dan, although .to_mm.to_mm.to_mm looks like some kind of comedy code. I gotta say Ruby seems the most obscure, non-sensical language I have used so far.
            Of course it does. It's not Ruby's fault, that is not Ruby best practice.
            There are many "missing" methods in various API classes.
            In fact what we are missing here, are Area and Volume classes. When you multiply 2 Length instance objects, they get converted to Float.. and then you cannot tell what the math ops were to end up with the value.
            In other words... math on a Length object, by any other Numeric subclass, should return a new Length object. (Like adding the frontage of building lots along a right-of-way, or math ops with wall lengths to arrive at a perimeter length.)
            Multiplying two Length objects, should return a new Area object.
            Multiplying 3 Length objects, OR an Area object by a Length object, should return a new Volume object.
            However, multiplying Area objects, by other non-length Numeric objects, should result in a new larger Area object.
            .. etc.
            Problem is, current version of SketchUp would not know how to handle these new classes.
              http://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
              • Dan RathbunD
                Dan Rathbun
                πŸ‘ πŸ‘
                NO faults that I can see, after a quick read.
                  @dan rathbun said:
                  :thumb: πŸ‘
                  I'm sure there's some input to be made on the library I posted at GitHub - linked at the bottom. I'd collected it from various helper methods from different plugins of mine. The volume and area functions was originally not in separate classes - but I liked idea idea of Area and Volume as separate classes.
                  • Dan RathbunD
                    Dan Rathbun
                    @thomthom said:
                    @dan rathbun said:
                    ... but I liked idea idea of Area and Volume as separate classes.
                    I also ! (as I said above.)
                    And the API needs these, and the app needs to use them.
                      And locale handling for Floats.
                        Yes - agree. Your idea about multiply two Length to get and Area, and Area with Length to get a Volume is very elegant. I'd very much like to see this into SU9.
