Return values
100.mmbecomes aLengthclass (which is inches.)You must convert back mm, using
.to_mm, but because you cubed it, you have to "cube" the conversion"%fmm#{179.chr}" % (@width * @breadth * @height).to_mm.to_mm.to_mmsee Kernel.sprintf() for info on format strings
Thanks Dan, although .to_mm.to_mm.to_mm looks like some kind of comedy code. I gotta say Ruby seems the most obscure, non-sensical language I have used so far.
.to_mm, but because you cubed it, you have to "cube" the conversionIt's better to use
.to_l- then when thatLengthinstance is outputted as string it's printed in the user's units.
As for area - useSketchup.format_areaUnfortunately there is no method for volume - they left that one out. So in that particular instance you need to write the conversion from cubed inches to user units yourself.
prompts = ["Width mm", "Breadth mm", "Height mm"] defaults = ["100", "100", "100"]Let SketchUp handle the units for you. If you feed the input box
Lengthobjects as defaults - it converts the user input toLength's for you.
defaults = [100.mm, 100.mm, 100.mm]It's better to work with units in SketchUp's units - internally inches - and always ensure you have
Lengthobjects when you output to the user. That way the user gets the units in his/her preferred unit and you don't have to do a thing. -
There was another topic on this issue, I think I may have posted a method in there.
Or.. hmmm... It may have a "[Code]" prefix in the title.
ADD: found it: Volume of Multiple Groups
You might get some ideas from that, and there is a link to one of TIG's old utilities.
Anyway.. TT... One thing you or TIG have not done yet is a "Units: The Lost Manual"
That is in fact on my list to write up.
.to_mm.to_mm.to_mmlooks like some kind of comedy code. I gotta say Ruby seems the most obscure, non-sensical language I have used so far.Of course it does. It's not Ruby's fault, that is not Ruby best practice.
There are many "missing" methods in various API classes.
In fact what we are missing here, are
AreaandVolumeclasses. When you multiply 2Lengthinstance objects, they get converted toFloat.. and then you cannot tell what the math ops were to end up with the value.In other words... math on a
Lengthobject, by any otherNumericsubclass, should return a newLengthobject. (Like adding the frontage of building lots along a right-of-way, or math ops with wall lengths to arrive at a perimeter length.)Multiplying two
Lengthobjects, should return a newAreaobject.Multiplying 3
Lengthobjects, OR anAreaobject by aLengthobject, should return a newVolumeobject.However, multiplying
Areaobjects, by other non-lengthNumericobjects, should result in a new largerAreaobject... etc.
Problem is, current version of SketchUp would not know how to handle these new classes.
http://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
NO faults that I can see, after a quick read.
@dan rathbun said:
:thumb:
I'm sure there's some input to be made on the library I posted at GitHub - linked at the bottom. I'd collected it from various helper methods from different plugins of mine. The volume and area functions was originally not in separate classes - but I liked idea idea of Area and Volume as separate classes.
And locale handling for Floats.
@dan rathbun said:
And the API needs these, and the app needs to use them.
Yes - agree. Your idea about multiply two Length to get and Area, and Area with Length to get a Volume is very elegant. I'd very much like to see this into SU9.
