    Increase the quality of export in LayOut 3, Mac OS X?
    layout
    5 Posts 4 Posters 1.0k Views 4 Watching
      jkiffer
      When I export to pdf from LayOut 3, Mac OS X, I was offered only three options: "low quality, medium quality and high quality."
      I would like to export very high quality without aliasing.
      Is there a solution, a plugin, a hidden option in LayOut, in order to adjust the resolution of the exported file in pdf LayOut? To adjust the resolution in DPI, perhaps?
      Thank you in advance for your help.
      Jeremy
      • cottyC Offline
        cotty
        @jkiffer said:
        Jeremy
        (Depending on your model) you can use vector output for ultimate quality 😎
        my SketchUp gallery
        • bmikeB Offline
          bmike
          @jkiffer said:
          Jeremy
          Do you have your viewports setup to render in vector / hybrid / raster?
          Can you attach a sample PDF and LayOut file?
            sonder
            Have you tested each? Even the low quality, at least on the pc is a very high quality compared to most PDF writers. In fact, I never go higher than medium to keep the file size down.
              jkiffer
              Bonjour,
              Je travaille sur la version Su Pro 8.0.16845 actuellement.
              Lorsque que je veux lance "gĂ©nĂ©rer un rapport", la fenĂȘtre s'ouvre, mais reste blanche. Puis rien ne se passe.
              Quelqu'un a-t-il déjà eu ce problÚme, et réussi à le résoudre, svp ?
              Jkiffer
