    Creating object panoramas
    5 Posts 4 Posters 388 Views 4 Watching
      dbion
      I want to creat an 360° object panorama (not inside of a room but) of an object, a chair for example. I found this software from garden gnome to do it http://gardengnomesoftware.com/object2vr.php I can use it to export quicktime or flash files. Even better would be Java Script or HTML 5 if this is possible.
      My question is: is there a plugin to create all the required camera positions for this kind of object. Or do you know a better way how to do it? I know there is the Google SketchUp Web Exporter but I want to render it with Vray first.
      Any help would be highly appreciated!
      • sdmitchS Offline
        sdmitch
        On my blog I have a plugin named Spin_It which rotates an object or the view. If you select view, the "Record" option creates a scene from each camera position. It might be of some help with what you are trying to do.
        http://sdmitch.blogspot.com/
          mwm5053
          I noticed you use a mac, if you have an ipad or iphone you might want to look at this.
          (itunes.apple.com)
          after I re read your post this probably not what you looking for.
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
            dbion
            @sdmitch
            Thank you, I will give it a try.
            @mwm5053
            right, I don't want to create it with the IPad, I want to create it and run it on an IPad.
            • Didier BurD Offline
              Didier Bur
              Take a look at this script I wrote a long time ago, check if it works with SU8:
              http://rhin.crai.archi.fr/rld/plugin_details.php?id=467
              Regards
              DB
