Setting Measurements
Hi everybody :
Question : Is there a way to set, in the user TEMPLATE, a set height for projects ? I was using the component 'Sang' as a guide. But, I just did a check on his height, using the tape measure, and he's 33' in height. I'd like to be able to use Sang as a guide (for the average height). This way, any models that I create will be of 'normal' height. So I won't have to do too much adjusting when I insert the model(s) into a project. Or, can I just a 'redo' my "Opening Template", and adjust Sang's height, then resave "Opening Template" ? garystan -
That Sang must have been modified somehow in your template. But measure it again with the tape measure tool and type in what you think is "normal". SU will ask if you want to resize your model (in this case only Sang).
