    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 262.7k Views 54 Watching
    • KrisidiousK
      Krisidious
      so what are some examples of what you would use this for?
      By: Kristoff Rand
        MattC
        For me it is for a interior decoration purposes.
        Like a wall panel ,or sort of sculpture.
        Matt
        • mitcorbM
          mitcorb
          I notice you use the name Delaunay and Delauney in this post. Could the various spellings affect functionality of the script? Or, are they not the same thing?
            MattC
            Yup , my fault.
            I've corrected it. there should be delauney3.rb as it uses that ruby for triangulation. Triangulation name is Delauney Triangulation.
            Matt
              Nice plugin! 👍
              However, Looking at the code I see that there are many methods on the global namespace. These methods will spread to ALL classes - which is not good. Could you please wrap everything into a separate unique namespace - module? Everything, even all the classes etc.
              Have a look at this article I put together with guidelines for SketchUp plugins: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
              • srxS
                srx
                Thanks! 👍
                www.saurus.rs
                • mitcorbM
                  mitcorb
                  Forgive my further ignorance, please. Why is it called "Conic Curve?"
                    Some Voronoï fractures in Blender 😉
                    [flash=560,315:3l0fl5l0]http://www.youtube.com/v/FIPu9_OGFgc[/flash:3l0fl5l0]
                    • I
                      ivreich
                      Hi MattC
                      Thanks for this plugin..been looking for something like this for a while.
                      Anyway, I gave it a go and am experiencing lots of problems generating a proper voronoi lattice. have attached a screenshot and also the SU file for you to look at.
                      Cheers,
                      Joel
                      Voronoi XY Errors
                      Voronoi XY Errors SU File
                      • KrisidiousK
                        Krisidious
                        SO Matt are you saying if I had a box shaped plan I could plan a curve through it to fit well?
                        By: Kristoff Rand
                          MattC
                          Could You show me an example of box shaped plan and what You would like to obtain ?
                            Cool things in 3D 😉
                            http://matsysdesign.com/wp-content/uploads/2009/06/drawings_01_voronoi3d.jpg
                              Or something else
                              Just image found on the Net 😉
                              But will be easy to make with your futur plug! ☀
                                MattC
                                Pilou You 're teasing me 😄
                                Is it Sketchup ??
                                Or something else?
                                Well only step that I miss from those, is generation of 3D Voronoi 😄
                                For rest I have plugins already.
                                @ Joel, indeed there WAS a problem - file in first message is updated.
                                Matt
                                • N
                                  nektares
                                  Hey i always loved voronoi structures and i´m very interested on this plugin but when i try to use it i get this:
                                  Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:277:in point_in_polygon_2D' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:277:in voropoints'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:267:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:267:in voropoints'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:128:in voronoi' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:105:in each'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:105:in voronoi' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:36:in initialize'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:384:in `new'
                                  am i doing something wrong, i read carefully and i think it´s my SketchUp maybe?
                                    MattC
                                    Hi Can You attach sketchup file that is causing problems, or is it in general ?
                                    Matt
                                    • T
                                      the.pjt
                                      HI Matt ...
                                      I have made some PNG Icons ,made a loader and toolbar , define Extention for your exelent codes , and developed them a bit 😉
                                      added a custom cursor to the ConicCurveInFace.rb
                                      and removed the annoying UI message-box group counter from VoronoiXY.rb
                                      I have also added TIG's pointcloude script as a defoult part of it , and I also made a Icon for that tool too ( points cloud triangulation ) .. I also made codes nicely and full commented .. just for you dear main developer 😄
                                      suggestion for next versions :
                                      add a point cloud generator ruby tool
                                      add option to decide the resoult of VoronoiXY tool should be grouped or not
                                      add option (ConicCurveInFace.rb) that let user make ConicCurves from grouped face (resoult of VoronoiXY tool)
                                      add option (ConicCurveInFace.rb) that let user make ConicCurves from a set of selections .. no need to click and click and click ... 😄
                                      and ... thanks a lot for your great script
                                      to dear modorators : please please please don't delet this post !!! 😢 .. TIG says :
                                      Permission to use, copy, modify, and distribute this software for
                                      any purpose and without fee is hereby granted, provided that the above copyright notice appear in all copies... I didn't delete that copyright part .. and I also added TIG's name after his tool menu item ! 😉 is there any copyright issue again ? [mod=:3b85s0b6]PLEASE GET/USE THE LATEST VERSION...
                                      FROM THE PluginStore...[/mod:3b85s0b6]
                                      voronoi_conic.zip
                                      • T
                                        the.pjt
                                        here is the PSD files of ICONS
                                        icons.zip
                                          This one is ok - as it has explicit statement that it can be modified and distributed.
                                          We do however prefer that the downloads for plugins at in the very first post of a plugin's thread. Otherwise it's hard for people to find the latest version if it is buried deep inside the thread. Could you agree with Matt whether that Matt puts the download in the first post - or you create a new thread where you maintain this modified version?
                                          • U
                                            unclex
                                            wonderful
                                            • 1 / 7
