    Spaceship (Collaborative Project)
    281 Posts 14 Posters 65.4k Views 14 Watching
    • iichiversiiI Offline
      iichiversii
      So does the pod double as a shuttle?
      Bring on the Rain...
      • MarianM Offline
        Marian
        I don't think so. It might be too big and it's not very aerodynamic...maybe.
        I want to have the general shape of the whole ship finalised first and then we can think of adding stuff and improving it.
          iichiversii
          ๐Ÿ˜† you can fly it then, I'll take my chances with the vacuum of space ๐Ÿ˜ฒ
            iichiversii
            It will proberly be tomorrow I'll post what I have, but it's coming on nicely ๐Ÿ‘
            • MarianM Offline
              Marian
              Good, good. Carry on. ๐Ÿ˜›
                iichiversii
                Ok i decided to post an early example of the seperation sequence, i would like to add some parts seperating from the side, i made a few alterations to the ship, is this another "NEIN NEIN NEIN" moment or a ๐Ÿ˜ฎ and ๐Ÿ˜ฒ moment.... ๐Ÿ˜†
                Again watch the animation of the seperation squence ๐Ÿ‘
                AutoSave_LOWERPOLY_STARSHIP_CONCEPT_updates.tweens.skp
                  iichiversii
                  I wasnt so happy with the privious animation, the ship just didnt look right, so made a few more mods and removed some parts, also im going to redo the seperation squence at the front, again watch the animation ๐Ÿ‘
                  • MarianM Offline
                    Marian
                    I like the animations and some things you did with the ship, but the first one is anything but sleek and sexy.
                    Though I like those I still can't except them as permanent. I don't think the animation are too productive right now. I make something, you make something and an animation, I have to redo a lot of stuff, then you have to redo a lot of stuff which makes me have to redo stuff and so on and so forth......
                    I WANT THE FINAL SHAPE OF THE SHIP.
                    Can we focus on that please?
                    https://encrypted-tbn2.google.com/images?q=tbn;ANd9GcQFxI4Qisg_A2AW7VwSrr6WMAdf_ra2iEL0lZgUwxQ0k85H5obHMQ
                      iichiversii
                      Yeah I taught the first 1 looked too bulky, that's why I redid it again, ok besides he animation of the separation sequence, what about the shape of the ship, I'm finding it hard to visualise the main body with what we have so far, any ideas?
                      • MarianM Offline
                        Marian
                        I think we pretty much have it length wise, I'm not satisfied with the shape at the back yet so I'll make some modifications.
                        You're having trouble with visualising it because I don't work with a specific shape in mind, I'm modifying it until I like it.
                        You can think about the engine section, we could make it separate from the main body. I think you'd love a dettachable engine section that slides into the main body. It doesn't need to be flush with the main body's contours. You can make something that you'd like and when it's done I'll then think about how to fit it.
                        I know it's not the way an engineer works...but this is art. After we have the whole body ready and smoothed we can carve it and add stuff to it. ๐Ÿ˜„
                          iichiversii
                          Yeah I noticed I'm the modeller who makes models that are engineered correctly with moving parts and ur the modeller who does it for style and art, none the less this is an interesting project, I always plan around how the model should work but I'll put that aside for now and help get the shape finalised first. So I was reading up on types of space craft and I found a forum on ufo's and the types there are, saucer, triangle and cigar shaped, now I know it's a ship and not really linked to UFO's but I see a cigar shape coming from this design, much like your last ship design which appeared on the last edition of catchup, the size of 200m is a perfect size also, we should exceed it, I was also thinking if it is cigar shaped we should go with a rear engine much like your last design too, not attached engines, it wound just create more problems, just a taught, what are your taughts on the shape Marion ?
                          • MarianM Offline
                            Marian
                            By attached engine I mean one big section at the back that hold the powerplant and thrusters.
                            I do agree that this ship give the impression of being bigger than just 200m. I'm doing now some modifications, that you'll just "love" ๐Ÿ˜† ๐Ÿ˜„)
                            EDIT: I think we should do 2 ships based on what we have so far but you take the lead on the next one and I'll try to adapt and since I've taken charge of this one you adapt to my work flow. I think this way we'll both be satisfied.
                            • MarianM Offline
                              Marian
                              Added a top component to the the long ship inspired from your animation.
                              I'm planning of redesigning the pod.
                              LOWERPOLY_STARSHIP_CONCEPT.skp
                              HIGHPOLY_STARSHIP_CONCEPT.skp
                                iichiversii
                                ๐Ÿ˜† guess what, i modified your model again, dont worry its just an alternative to modifying the pod, ๐Ÿคฃ
                                LOWERPOLY_STARSHIP_CONCEPT_MODS.skp
                                • MarianM Offline
                                  Marian
                                  That's not a bad modification actually. I'm still not sure if to adopt it or not, but it's not bad ๐Ÿ˜›
                                  Did some renders of the previous one.
                                  • MarianM Offline
                                    Marian
                                    Simlab Composer. I need to try Thea out next week. ๐Ÿ˜„
                                      iichiversii
                                      Holy shit , what render engine you using?
                                        iichiversii
                                        thats impressive rendering ๐Ÿ‘
                                        dont mind that mod i made, i was just messing around with it ๐Ÿ˜„
                                          iichiversii
                                          Marian heres art for ya ๐Ÿ˜†
                                          STARSHIP_ART.skp
                                          • MarianM Offline
                                            Marian
                                            LOL, that's spaceship revolver.
                                            • 14
                                            • 15
                                            • 6 / 15
