    Spaceship (Collaborative Project)
    281 Posts 14 Posters 65.4k Views 14 Watching
    • stefanqS Offline
      stefanq
      Yes guys, you are being watched. Now, I'm just jealous of you two, because you're having fun and TIME to do this. But. I can't imagine what your ship will look like. You guys definitely know your sh.t with all that terminology, but I for one, don't know the difference.
      "not a cluncker, streamlined explorer" and so on, but I think you should put here some references, if not for you, at least for us, the watchers.Like I said to Marian, I've already spent an evening browsing concept ships blog.
      So, what are you guys building? πŸ˜†
      • iichiversiiI Offline
        iichiversii
        Sure Stefang, we will explain our terminology in future, apologies mate, and cheers for the heads up πŸ˜„
        Bring on the Rain...
          iichiversii
          I have being, im just after redoing that last model i did last nite to reduce the poly count, its as close as i could get it, have some fun with it, tear it apart. add to it, bin it if you dont like it, πŸ˜„
          Removed the model for editing, found a few flaws after posting, will submit again as a new post 😳
          • MarianM Offline
            Marian
            Now how's this for a clash of styles? πŸ˜„
            Low poly version and subdivided version.
            LOWERPOLY_STARSHIP_CONCEPT.skp
              iichiversii
              Ok fixed the problem with the original model, πŸ‘
                iichiversii
                I dont know, its ok πŸ˜’
                🀣 thats brilliant, so we got a front section πŸ‘
                • stefanqS Offline
                  stefanq
                  I think is too compact for such a big ship. I'm browsing concept ships again. Darn!
                  By the way, I just bump into the USCSS PROMETHEUS .... sexyyyyy
                    iichiversii
                    What about making it wider like in this image, make it look more menacing
                    ALTERATION_STARSHIP_CONCEPT.skp
                    The image is far wider than the skp file, check it out πŸ‘
                    • MarianM Offline
                      Marian
                      Yeah, but it's not as sleek. Maybe a bit wider would be ok but that is way to wide.
                        iichiversii
                        Hows this?
                        • MarianM Offline
                          Marian
                          Neah...
                            iichiversii
                            You nailed it there, much better πŸ‘
                            • MarianM Offline
                              Marian
                              Yey. πŸ˜„
                              What's next?
                                iichiversii
                                If all else fails Marion at least we have a shuttle πŸ˜†
                                • MarianM Offline
                                  Marian
                                  Meh...I don't want a shuttle. πŸ˜›
                                    iichiversii
                                    @marian said:
                                    Yey. πŸ˜„
                                    What's next?
                                    I think the main body is next, since the front section is more or less on top/front it looks like we are going to need to build the main body from the top down, I usually work from the bottom up, but so far we have an interesting front section, it reminds me if the miny sub used in the DSV series if you remember, it operated like a dolphin where the tail worked like an organic flipper, I loved that show until it was cancelled, so main body, suggestions? Iv an idea that comes to mind which I'll work on later tonight πŸ˜„
                                    • MarianM Offline
                                      Marian
                                      Oh yes, I loved Seaquest too untill they went all Star Trek and then batshit crazy
                                      y.
                                      Yeah..keep it lowpoly and similar in style with the front, but I also may make something for the main body. πŸ˜„
                                      • MarianM Offline
                                        Marian
                                        πŸ˜„
                                          iichiversii
                                          That is very nice, let's keep that πŸ‘
                                          • MarianM Offline
                                            Marian
                                            Cool. So we could make the front separable in case of emergencies. I don't want to add big engines on it.
                                            • 14
                                            • 15
                                            • 3 / 15
