    Plugins
    8 Posts 8 Posters 2.6k Views 8 Watching
      chao_27
      guys, i wanna know what are the best plugins for sketchup. There's a lot of Plugins in the Index and i don't know what to choose. please help me. Thanks. ๐Ÿ˜„
      • numbthumbN Offline
        numbthumb
        There are really no such things as "best plugins for sketchup".
        It all depends on what are you using SU for - if youยดre interested in organic modeling, go for Artisan, and so on.
        Of course, getting a grip on SU native tools first would be a good start ๐Ÿ˜„
        Comfortably numb...
        • charly2008C Offline
          charly2008
          Hi Wilfritz,
          @numbthumb said:
          ๐Ÿ‘
          Look at the forum, as there are many threads dealing with plugins, So you will have an idea about the different plugins and their use. Just enter "plugin" into the search and you'll find a lot of threads.
          Charly
          • pbacotP Offline
            Places to start:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=16909
            http://forums.sketchucation.com/viewtopic.php?f=323&t=39504
            I know it's hard knowing what they are all for, but just browsing in the Plugins Index will give you an idea of the breadth of offerings. People could list their favorites but that changes according to the task at hand.
            Ones I use a regularly are Joint push pull, front face tool, and default layer geometry, Fredoscale, Extrusion Tools, Profile builder, Weld (or Recurve), CleanUp. But some of these are utilities for fixing up just about any project , while others are the fun powerful tools that you pull out for a task, then don't touch for a while again. So what's best?
            I think most people just work for a while then come up to a difficult task or wonder if there's a better way, search the forum for an answer, then if none is found, ask if there's a specific plugin. Others invent new plugins, bless them. โ˜€
            • cottyC Offline
              cotty
              You know that you have enough plugins if the start of SketchUp takes longer than 60 seconds (like mine) ๐Ÿ˜Ž
              (A simple solution is not to close it, except sometimes by bugsplats ...)
              A big advantage is that you then discover a new plugin almost every day. ๐Ÿ˜’
              my SketchUp gallery
                My own list of
                Indispensables โ˜€
                But as There are something like more 2 000 plugins that is a drastic selection! ๐Ÿ’š
                Extrude Line http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1523 by Didier Bur
                Joint Push Pull http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708 By Fredo6
                SmartPushPull http://forums.sketchucation.com/viewtopic.php?f=323&t=23341 by a4chitect
                Tools on surface http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212 By Fredo6
                Bezier http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a&hilit=bezier By Fredo6
                Extrude edges toolsExtrude tools by TIG
                CurviLoft By Fredo 6 ๐Ÿ˜Ž
                FredoScaleFree Scale Bend by Fredo6
                Shape Bender By Chris Fullmer
                Component StringerBy Chris Fullmer
                Cleanup by Thomthom
                Mirror http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11532&p=80373 by Frank Wiesner/TIG
                Grow (Multiple Copy Move rot size in same time! ) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Grow.rb by Tig
                Inverse Selection http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/InvertSelection.rb by Tig
                Extrude along a path http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/ExtrudeAlongPath.rb by Tig
                Double Line (Walls) http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12853 Didier Bur
                Weld curves (or lines) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/fr_weld.rb by Rick Wilson
                Projections by Didier Bur http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=960&st=0&sk=t&sd=a&hilit=projection+didier+bur
                FFD Box of deformation http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6029 by CPhillips
                Clean coplanar surface (inside this plug Skin) http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6912 by architectboy
                Follow me and rotate http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13014&st=0&sk=t&sd=a by wikii
                Follow me and keep
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16465&st=0&sk=t&sd=a&hilit=follow+rotate#p129504 by Wikii
                Taper, curve maker http://www.drawmetal.com/home by Draw Metal
                Animation http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10946&st=0&sk=t&sd=a by Morisdov
                Chris Fullmer http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17358&p=139011#p138625
                Selection Toys by Thomthom
                Subdive and Smoth (basic free) http://www.smustard.com/script/Subdivide by Ricks Wilson
                not free http://www.smustard.com/script/SubdivideAndSmooth by Whaat
                Funny
                SketchyPhysics http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=17324&st=0&sk=t&sd=a&hilit=SketchyPhysics#p138266 by CPhillips
                Protrude by Jim Folz http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13095&st=0&sk=t&sd=a&hilit=protrude#p95818
                Zorro2 http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16038&st=0&sk=t&sd=a&hilit=zorro2#p124862 by Whaat
                Soap Skin Bubble & Tensile structures (free) http://www.tensile-structures.de/help.html by Josef Leibinger
                Ferrari
                  @numbthumb said:
                  There are really no such things as "best plugins for sketchup". It all depends on what are you using SU for...
                  Indeed. When I look at Pilou' list for instance, I see a lot there that I do not use. Those are his picks while I have different ones I work with.
                    Trogluddite
                    I think the best way to choose plugins is to let practical work make the decision for you. (for any app' with plugin facilities).
                    Just get cracking on with some models using the standard tools, and identify..
                    A) Things you need to do, but the standard tools can't manage it.
                    B) Complex actions that you need to repeat a lot, and really want a quicker way to do it.
                    C) Recommendations from other forum users who are trying to solve the same problem as you.
                    ...then do a targeted search for a plugin to fit exactly what you need.
                    I find this much better than just loading lots of plugins "just to try them"; no matter how clever they are, they will just become HDD clutter if they are not truly useful to your models - and that clutter can be a real pain, as plugin file management (one big folder!) is a totally "manual" experience, and you will be glad that you have only a "slim" collection if you ever need to diagnose slow-boots or bugsplats!
                    There also comes a point when you can have so many plugin, that going back to the standard tools becomes faster than looking for some tutorial videos, to remind yourself how a rarely-used plugin actually works! So my big tip is this - consider carefully which plugins you DO NOT need, and eliminate them from your HDD mercilessly so that SU boots fast, and you are not swamped by extra toobars/menu items etc. that are no longer meaningful.
                    That will leave you enough (tidy!) room in your plugin folder for an occasional "experiment" with a new crazy plugin when you need inspiration to break out of "designer's block".
