    [Plugin] Frame3DD Sketchup Interface
    17 Posts 8 Posters 32.2k Views 8 Watching
    • KrisidiousK
      Krisidious
      wow... very kool. thanks. I build cars for a simulator using SketchUp. This will come in handy I'm sure.
      By: Kristoff Rand
        Michaelv
        Awesome! That is all.
        I have a feeling that it doesn't work yet on Macs. Since GNUplot and Frame 3DD do, I was going to look at it and try to make it work as much as possible.
        Oh well I just saw it's scrambled. Contact me if you're interested to make it work. We'll see how I can help.
          Michaelv
          There is another thread about FEA and that mentions frame3dd at the end, just in case you missed it:
          404 Not Found
          (forums.sketchucation.com)
          • O
            oyil
            404 Not Found
            yup missed that one. but its a request to include frame3dd with the spring mass model plugin.
            • O
              oyil
              i guess we'd have to make frame3dd and gnuplot work with Macs first.
              i, myself, am wishing for a sketchup on android. that would be a very good reason to get a galaxy tab 10.
              BOOOOOOOM!
                Michaelv
                BOOOOOOOM!
                Frame 3dd and Gnuplot work on Mac already.
                  a4chitect
                  this looks very promising - thanks for sharing
                  I would prefer seeing the result (even better - immediate feedback) directly in sketchup, like an old game called bridge builder - where you drew lines and could see their condition under pressure by changing their color from green to red. this could help in the initial 'sketchup' phase of designing structure
                  • G
                    glro
                    i agree
                    Sketchup can be a much better viewer than GNUplot; i have a structural analysis software, with post processing features, but for textile structures for example, the result is better when i import the nodes position (X Y Z) output from the structural analysis software, into sketchup, using "cloud_v8.rbs" and "TIG_points_cloud_triangulation.rb"
                    The result is much more realistic
                    Apart from that, congratulation to Oyil for this plugin ! it widens, even more if possible, sketchup potential applications
                    textile structure
                    • W
                      watkins
                      Don't forget this:
                      and for SpaceClaim users:
                      Regards,
                      Bob
                      • O
                        oyil
                        @a4chitect said:
                        came across this> http://sketchstruct.drupalgardens.com/
                        input is sketchup simple 😉 would prefer seeing the results graphically, but this could be easily integrated in another plugin/ruby just to visualize the results
                        and moving the vertices along with loads would also be preferable for a quick optimization
                        yup. saw that. tried it. but its 2D. not what i need.
                        i am now trying to figure out how to make the icons for the toolbar buttons. how?
                          a4chitect
                          a hot-stitched plugin to visualize its results (just for playing)
                          (after running sketchstruct select all frame members (edges) and run plugin Visualize "Sstruct" from Plugins menu
                          colors: green is zero force, red is maximum positive force, blue is maximum negative force, black is "data missing"
                          F5-bigger size F6-smaller size
                          A4_visualize-sketchsstruct.rb
                          • O
                            oyil
                            i tried it. but i think frame3dd can do more. thanks for the suggestions.
                              a4chitect
                              of course, this is childs-play compared to frame3dd possibilities, I just wish for a quick force visualization integrated into sketchup - to be able to optimize design of structure and explore possibilities. ideally this should happen in real-time within sketchup
                              • L
                                Loveday
                                Dont know if this post is dead - oyil, I am trying to use your plugin for simple two dimensional truss analysis - run the plugin - Frame3dd starts processign then error message: "the number of load cases must be at least one". Any ideas of what may be wrong? I have created the geometery, applied material, set constraints and loads.
                                • O
                                  oyil
                                  load case on 3dd iput file maybe missing or the entire data was not written to the temporary 3dd import file.
                                    Johnwang
                                    Just found frame3dd. Will try this.
