Import .MAX into Trimble Sketchup with textures
Is there anyway to Import .MAX into Trimble Sketchup with textures or convert it for free and then import with textures? As I am not entirely sure where to post this I have also posted it under 'Resources'
No there is not a direct option to do this. There is an .fbx importer floating around, or try collada. I found the best method is Deep Exploration through the .rh extension. Export out of Max as .rh and then use DE to convert to .skp. Expensive option, but works very well.
