    3ds files
    6 Posts 5 Posters 440 Views 5 Watching
    • B
      brianmccuk
      When I import a 3ds file it comes in as various triangles? can I reduce this?
      Thanks,
      B
        maybe with Meshlab ?
        • Jean LemireJ
          Jean Lemire
          Hi folks.
          If you have SU Pro, you can try exporting as a DWG and then import back with the Merge coplanar faces option checked.
          Just ideas.
            jpalm32
            My Meshlab can't imports 3DS
            • N
              Nentautako
              @brianmccuk said:
              Thanks,
              B
              have you ever heard about POLYGON CRUNCHER 10.1 ?
              just download the standalone trial and modify the overlay file... you would use if forever πŸ‘
                Meshlab
                import:PLY, STL, OFF, OBJ, 3DS, COLLADA, PTX, V3D, PTS, APTS, XYZ, GTS, TRI, ASC, X3D, X3DV, VRML, ALN
                export:PLY, STL, OFF, OBJ, 3DS, COLLADA, VRML, DXF, GTS, U3D, IDTF, X3D
