[Plugin] ZoomZoom_dj v2,6 March 17, 2013
zoomZoom_dj v2.6
Copyright March 17, 2013
DukeJazz: by James CochranFreely use, and abuse at your own risk. Fitness of usage is not warranty implied.
7 Simple double zoom pc tools
ZoomWindowSelect_dj, zoomZoomPushPull_dj,
zoomZoomPolygon_dj,zoomZoomScale_dj,
zoomZoomMove_dj, zoomZoomRotate_dj and zoomView_dj.
Hit space bar to select,
Hit c key for circles,
and r for rectangles
If nothing is selected with the select tool and you press[ok] it will then be a zoom window command. (nice) and if you selected somthing and you press[ok] it will zoom to sected enitities group and return you to the zoom window. (nice) and continue to a tool if you choose too. (great) and/or a side view. (Wow!)Helps in viewing a very small object with sizes .001 or less, or getting the view of small detail on a large object.
History:
Ver. 2.6 March 17, 2013- grouping to zoomZoom_dj v3.6, ZoomWindowSelect_dj, ZoomZoom_dj and ZoomVeuw_dj
- plugins wrap in Module DJ::pluginsName.methodDJ(name space)
- @variable format (name space) dj_variable
- plugins are in subject and name order (easy to look up)
- Name changed from ZoomView_dj to zoomZoom_dj
Ver. 3.0 June 28,2012 -ZoomView_dj
-name change
-Turn into one button menu control for many more zoom and view featuresVer. 2.0 June 14,2012 -ZoomZoom_dj
-upgrade
-5 more functions
-name change
(7.7 KiB) Downloaded 77 timesVer. 1.0.2 June 9 -ZoomWindowSelect_dj
-turn on UI.menu for hot key support
(1.92 KiB) Downloaded 38 timesVer. 1.0.1 June 8 -ZoomWindowSelect_dj
-fix miss labled tool bar
(1.92 KiB) Downloaded 34 timesVer. 1.0 June 8 -ZoomWindowSelect_dj
release:(1.94 KiB)
(1.94 KiB) Downloaded 23 timesDownload
Ver. 2.6ZoomZoom_dj v2.6.zip
Ver. 2.0
(7.7 KiB) Downloaded 190 times -
zoomWindowSelect_dj Ver. 3.0 -ZoomView_dj
Copyright 2012, June 28
Simple One button double zoom, view and style. (API)
Has 13 zooms, 12 views and 11 styles features.Now you can use view and style features.
If nothing is selected with select tool and you press[ok] it will then be a zoom window command. (nice) and if you selected somthing and you press[ok] it will zoom to sected enitities group and return you to the zoom window. (nice) and continue to a tool if you choose too. (great) and/or a side view. (Wow!)
The zoom works but nothing else for me?
Each level as its users.
When I up grade something it hard to get recognition to similar but different stand alone program, .... thus by threading a new post helps. ... also the old program can't be discarded because it maybe the most wanted to the users. Sometime bigger is not better.
