    [Plugin] ZoomZoom_dj v2,6 March 17, 2013
    5 Posts 2 Posters 9.6k Views 2 Watching
    • dukejazzD
      dukejazz
      zoomZoom_dj v2.6
      Copyright March 17, 2013
      DukeJazz: by James Cochran
      Freely use, and abuse at your own risk. Fitness of usage is not warranty implied.
      7 Simple double zoom pc tools
      ZoomWindowSelect_dj, zoomZoomPushPull_dj,
      zoomZoomPolygon_dj,zoomZoomScale_dj,
      zoomZoomMove_dj, zoomZoomRotate_dj and zoomView_dj.
      Hit space bar to select,
      Hit c key for circles,
      and r for rectangles
      If nothing is selected with the select tool and you press[ok] it will then be a zoom window command. (nice) and if you selected somthing and you press[ok] it will zoom to sected enitities group and return you to the zoom window. (nice) and continue to a tool if you choose too. (great) and/or a side view. (Wow!)
      Helps in viewing a very small object with sizes .001 or less, or getting the view of small detail on a large object.
      History:
      Ver. 2.6 March 17, 2013
      • grouping to zoomZoom_dj v3.6, ZoomWindowSelect_dj, ZoomZoom_dj and ZoomVeuw_dj
      • plugins wrap in Module DJ::pluginsName.methodDJ(name space)
      • @variable format (name space) dj_variable
      • plugins are in subject and name order (easy to look up)
      • Name changed from ZoomView_dj to zoomZoom_dj
      Ver. 3.0 June 28,2012 -ZoomView_dj
      -name change
      -Turn into one button menu control for many more zoom and view features
      Ver. 2.0 June 14,2012 -ZoomZoom_dj
      -upgrade
      -5 more functions
      -name change
      (7.7 KiB) Downloaded 77 times
      Ver. 1.0.2 June 9 -ZoomWindowSelect_dj
      -turn on UI.menu for hot key support
      (1.92 KiB) Downloaded 38 times
      Ver. 1.0.1 June 8 -ZoomWindowSelect_dj
      -fix miss labled tool bar
      (1.92 KiB) Downloaded 34 times
      Ver. 1.0 June 8 -ZoomWindowSelect_dj
      release:(1.94 KiB)
      (1.94 KiB) Downloaded 23 times
      Download
      Ver. 2.6
      ZoomZoom_dj v2.6.zip
      Ver. 2.0
      (7.7 KiB) Downloaded 190 times
      • dukejazzD
        dukejazz
        zoomWindowSelect_dj Ver. 3.0 -ZoomView_dj
        Copyright 2012, June 28
        Simple One button double zoom, view and style. (API)
        Has 13 zooms, 12 views and 11 styles features.
        Now you can use view and style features.
        If nothing is selected with select tool and you press[ok] it will then be a zoom window command. (nice) and if you selected somthing and you press[ok] it will zoom to sected enitities group and return you to the zoom window. (nice) and continue to a tool if you choose too. (great) and/or a side view. (Wow!)
          mwm5053
          The zoom works but nothing else for me?
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • dukejazzD
            dukejazz
            Each level as its users.
            When I up grade something it hard to get recognition to similar but different stand alone program, .... thus by threading a new post helps. ... also the old program can't be discarded because it maybe the most wanted to the users. Sometime bigger is not better.
            • dukejazzD
              dukejazz
