    How to protect your plugins code
    5 Posts 4 Posters 1.4k Views 4 Watching
    • T
      tlnguyen
      hello everybody,
      our team has developed a Sketchup ruby plugin and we now want to "lend" it to a partner. So is there a way to protect our ruby code? and is there a way to remotely control its use?
      thank you very much,
      regards,
      tlnguyen
        https://developers.google.com/sketchup/docs/tutorial_distributing ?
        • Dan RathbunD
          Dan Rathbun
          You can scramble them:
          SketchUp Ruby Script Scrambler
          Beware:
          1) The global functions FILE and LINE cannot be used within files that you will later scramble into RBS.
          The Sketchup.load() and Sketchup.require() methods have internal errors in their decryption code, that do not translate the filepath and line.
          2) If you use SketchupExtension class plugin registration, this class cannot call a rbs file directly. It must call an unscrambled rb file ("the loader file") that has nothing but, one or more, Sketchup.require("myfile") calls in it.
          I'm not here much anymore.
            I am not inferring that you are doing anything 'wrong'...
            But 'remotely controlling' a tool with encrypted-code seems to be too much like malware/adware/trojanware/virusware/etc...
            I certainly wouldn't want to load a .rbs file from an 'untrusted' source, and if I found I was using one that was 'doing things behind my back without my permission', then I would certainly not trust it any longer !
            Imagine the havoc such a tool could wreak on someone else's PC in the wrong hands...
            • Dan RathbunD
              Dan Rathbun
              Do you mean license management ?
              "Control it's use"... in what way(s) ??
