    Getting the "circle steps" ???
    11 Posts 4 Posters 314 Views 4 Watching
      ksor
      Now I need to get the "steps" a circle is build of (standard is 24) but it can be changed dirung a session and then resets to 24 again when SU is restarted.
      How can I "get" this "step" as a number and use it in my code ?
      Best regards
      KSor, Denmark
      Skype: keldsor
      • Dan RathbunD Offline
        Dan Rathbun
        A circle is a Sketchup::ArcCurve instance.
        All classes in Ruby inherit methods from their superclass (and it's superclass, and the superclass of that, .. and so on, back to Object [which has module Kernel, mixed into it.])
        So ...
        Sketchup::ArcCurve.superclass %(#008000)[>> Sketchup::Curve]
        Looking at the API for Sketchup::Curve, we find:
        count_edges()
        I'm not here much anymore.
          Dan Rathbun
          By the Way.. the actual default is hard-coded and cannot be changed by the user (manually, or easily by code.)
          This is one of the common feature requests that SketchUp does not yet have.
          The "current" value of Curve segments is kept internally by SketchUp.. and is not yet exposed via the Ruby API. (Nor is it saved in the defaults in the Registry/Plist.)
          Access to it is one of the API feature requests that has been logged.
            ksor
            Argh ... thx anyway Dan !
            Best regards
            KSor, Denmark
            Skype: keldsor
              You can of course change the segments of an Arc/Circle, in code as you make it.
              I recall someone once wrote a PC only script that auto-loaded and ran as Sketchup started [you could also use an observer to ensure the setting applied to new SKP files in that session].
              It ran some winscript shortcut=C] to make a circle inside a temp-group and did various key-strokes for segments/radius/etc [36s/1 etc] - then it immediately erased the circle-temp-group.
              The new segment number is then used that session for all new circles...
                Michaelv
                Is there a way to batch change in a script?
                I.e. I run a script and the first action is to change all arcs and circle to a number of segment such that each segment is smaller than xxx.
                  Dan Rathbun
                  Yup.. that's what I meant by "not easily."
                    Dan Rathbun
                    You may be able to iterate the Curve's edges ( curve.edges.each ) and split each one at it's midpoint ( edge.split ) .. don't know. I never tried it.
                    Otherwise, .. you would have to recreate them I think. Get each one's start point, end point, center, angle, and make a new one to replace it. Delete the old one.
                      Dan Rathbun
                      Just tried it at the console. It does indeed split each edge. BUT ... the new vertices remain at the center of the chords. (They do not move out to the circumference, like they do if you use the native "DivideTool.")
                      And I do not see an API method equivalent for that tool.
                        My "ArcCurve-set_segments" tool lets you change the segments of selected Arcs, just as you could using Enity Info on each one... you are also bound by the same limitations - e.g. you can't change the segments if the Arc is part of a 3d object...
                        e.g. In the Ruby Console typing
                        changearcsegments 360
                        makes selected [eligible] Circles have 360 segments...
                          Michaelv
                          Argh, that's exactly what I was envisioning to do (a 3D object application). Well it makes sense that it cannot be done on the volume by changing the segments of the generating geometry. I didn't think of that.
                          Thanks for the answers.
