    Full Size Patterns for Templates [Updated]
    27 Posts 6 Posters 4.4k Views 6 Watching
      Could you post the SKP file you're using for this?
        john Msrk Power
        Dave,
        Sorry for the delay. I had problems uploading the SKP file using mozilla and had to use explorer instead. I hope this helps and than you for your time and expertise.
        -John Mark
        John Mount Chair 1 Templates.skp
          John, I'm happy to help if I can.
          Try exploding the components and see if that helps. If you don't need the rectangles around the edges, you might as well delete them. You could probably also stack the smaller template above the larger one and get them both on the same sheet. Try it with the attached file. I'm on my Mac and don't have access to my PC at the moment so I can't try it.
          By the way, you have the components nested although it doesn't appear that there's any reason for the multiple levels of components for each of them.
          And you asked about the multiple shadows in my images. Somewhere I did a tutorial on how to do that. It is not a plugin but rather the combination of images. I export the shadows separately from the faces and edges. For the final image of the tables, I have the edges, faces and two different shadows in four images.
          John Chair templates.skp
            john Msrk Power
            Dave,
            Thanks as always. Exploding it seemed to solve the problem. The SKP File is a work in progress. I have attached a model that is more or less complete. Thank also for the info on multipe shadows. I will look for that post on this site or the click design build site.
            John Mount Chair 1 Bent Post with color.skp
              Glad that worked for you.
              I'll have to hunt up that tutorial. I think I did it here.
              Good work on the chair.
                john Msrk Power
                Thanks Dave,
                The chair is a model of some chairs made locally in the 19th century. I have beeb drawing different examples in hopes of making some reproductions. The templates will be great when turning the posts and making the slats.
                -John Mark
                • bazB Offline
                  baz
                  I'm having the same problem as Kurt. I would find this very useful.
                  The GK plugin folder etc is in my plugins folder but no GK command appears in the 'Tools' menu.
                    There's an updated version of the plugin now. It has had some rewriting to avoid the problems some folks had with it loading properly and it is now Mac compatible.
                    • HumpmetwiceH Offline
                      Humpmetwice
                      Its working great for me thanks all to Dave's help!
                      • bazB Offline
                        baz
                        Its working great for me thanks for all Dave's help!
                        +1 πŸ‘
                        • 2 / 2
