    Full Size Patterns for Templates [Updated]
    27 Posts 6 Posters 5.0k Views 6 Watching
    • HumpmetwiceH
      Humpmetwice
      Hope this is what you needed Tig and yes Dave I open Sketch up after installing.
        Kurt, do you have administrative rights to install plugins to the Plugins folder?
        • HumpmetwiceH
          Humpmetwice
          Yes Dave I have installed many plugins before maybe to many.
            john Msrk Power
            Dave,
            This looks like an extremely useful tool. However, I have installed it correctly I think and what I get is a blank sheet in Ghostview. Actually, I get the template isolated in my screen at the origin of the red and blue axis, I set the camera to parallel projection. Next I scroll down the tools menu until I find "gk Postscript plot" and click on it. The next pop up screen asks me for a paper size. There is no pop up screen explaining the markers. a second screen tells m the directory that the file has been saved in. I then go to that file and open it. It opens up the Ghostview program. I have attached a screen shot to this post of the results. If you or anyone else can help me solve my problem that would be great. Also, how did you get the double shadows seen in the image of the tilt top table? Is that a plugin as well? Thanks in advance for any help. Maybe I should try reinstalling everything. I did install Gk postscript plot first. Perhaps it was the order I installed the software.
            Thanks,
            John Mark
              Could you post the SKP file you're using for this?
                john Msrk Power
                Dave,
                Sorry for the delay. I had problems uploading the SKP file using mozilla and had to use explorer instead. I hope this helps and than you for your time and expertise.
                -John Mark
                John Mount Chair 1 Templates.skp
                  John, I'm happy to help if I can.
                  Try exploding the components and see if that helps. If you don't need the rectangles around the edges, you might as well delete them. You could probably also stack the smaller template above the larger one and get them both on the same sheet. Try it with the attached file. I'm on my Mac and don't have access to my PC at the moment so I can't try it.
                  By the way, you have the components nested although it doesn't appear that there's any reason for the multiple levels of components for each of them.
                  And you asked about the multiple shadows in my images. Somewhere I did a tutorial on how to do that. It is not a plugin but rather the combination of images. I export the shadows separately from the faces and edges. For the final image of the tables, I have the edges, faces and two different shadows in four images.
                  John Chair templates.skp
                    john Msrk Power
                    Dave,
                    Thanks as always. Exploding it seemed to solve the problem. The SKP File is a work in progress. I have attached a model that is more or less complete. Thank also for the info on multipe shadows. I will look for that post on this site or the click design build site.
                    John Mount Chair 1 Bent Post with color.skp
                      Glad that worked for you.
                      I'll have to hunt up that tutorial. I think I did it here.
                      Good work on the chair.
                        john Msrk Power
                        Thanks Dave,
                        The chair is a model of some chairs made locally in the 19th century. I have beeb drawing different examples in hopes of making some reproductions. The templates will be great when turning the posts and making the slats.
                        -John Mark
                        • bazB
                          baz
                          I'm having the same problem as Kurt. I would find this very useful.
                          The GK plugin folder etc is in my plugins folder but no GK command appears in the 'Tools' menu.
                            There's an updated version of the plugin now. It has had some rewriting to avoid the problems some folks had with it loading properly and it is now Mac compatible.
                            • HumpmetwiceH
                              Humpmetwice
                              Its working great for me thanks all to Dave's help!
                              • bazB
                                baz
                                Its working great for me thanks for all Dave's help!
                                +1 πŸ‘
                                • 2 / 2
