    How to Write variable value into test.txt file
    8 Posts 3 Posters 990 Views 3 Watching
    • I Offline
      isoz
      Hello guys my name is Gustavo and iam from Brazil, i would like to know how to how to Write variable value into (Ex:test.txt) file.
      Iam using this code inside WebConsole " File::open('c:\foo.txt', 'wb') {|f| f.write $variablename } " it Works!!! create a file and writes variable value but when i try this same code inside Script area give me this msg error
      String doesn't compile: Error in Script:
      File::open('foo.txt', 'wb') {|f| f.write 'ruby!' }
      File::open('c:\foo.txt', 'wb') {|f| f.write 'ruby!' }
      private method `open' called for MSketchyPhysics3::SP3xCommonContext::File:Class#<RuntimeError: Error in Script:
      private method open' called for MSketchyPhysics3::SP3xCommonContext::File:Class> C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/ControllerCommands.rb:1314:in initEvents'
      C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/ControllerCommands.rb:1342:in initialize' C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/ControllerCommands.rb:729:in new'
      C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/ControllerCommands.rb:729:in createBody' C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:387:in createBodyFromCollision'
      C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:254:in dumpCollision' C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:238:in each'
      C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:238:in dumpCollision' C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:763:in initialize'
      C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in new' C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in startphysics'
      C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1650:in physicsTogglePlay' C:/PROGRA~2/Google/GOOGLE~1/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1738 (eval):3:in call'
      (eval):3
      • sdmitchS Offline
        sdmitch
        Ruby uses the '' to quote the next character so in the script you either need to double the character '\' or use '/' instead.
        'wb' ??? Sketchup uses Ruby 8.? version and this may not be supported. I don't find this context in my Ruby reference book.
        http://sdmitch.blogspot.com/
        • I Offline
          isoz
          Hello Sdmitch! tnx!
          I tried what you told, but same error 😞 any ideia?
          File::open('c:/foo.txt', 'w+') {|f| f.write $variablename }
          Works fine on console but not into script box.
          • sdmitchS Offline
            sdmitch
            It could be something as simple as trying to write a file to the root directory. Windows Vista says that I don't have access even from the admistrator account.
            Try this
            	File;;open(File.join(File.dirname(__FILE__),'foo.txt'), 'wb') {|f| f.write $variablename }
            which will create the file in the script directory.
            • I Offline
              isoz
              Try this
              Tnx iam going to test this when i get home, but i think the problem is this (private method `open' called for....
              the Class File.open is private needs to be public i think.... where can i change this? where is this class?
                Try
                File.open(.....)
                works for me... πŸ˜•
                • sdmitchS Offline
                  sdmitch
                  I have never had a problem with File.open just the path string for the file regarding the use of "". The code I encluded in my last post was tested and worked in Ruby Web Console, Ruby Console, and a plugin.
                  • I Offline
                    isoz
                    I got it!!!! file.open works fine in webconsole, but inside script box dont! becouse open method is private.. so this is the code
                    File.send(:open,'c:\foo.txt', 'wb') {|f| f.write $f }
                    send "force" access to the method open. i think script box try to access File class and has no access.
                    Sorry for my english i hope you guys understand and tnx for the help.
