    Addict Tool?
    4 Posts 3 Posters 300 Views 3 Watching
      ryangarnett
      Hi All,
      I was wondering if anyone knows of a addict tool. Other modeling packages have a tool that allow you do this. What I mean by this is, if you have a face on the ground (ie: 2m X 2m) and you have a face 3 metres above the face on the ground that is smaller (ie: 1m X 1m) the addict tool will allow you to select both faces and will generate a closed shape with the tapper from the large face on the ground to the smaller face 3 metre above the ground.
      Any ideas, other than drawing all the faces individually.
      Thanks,
      Ryan
        mrossk
        if I understand your question, then Curviloft's "Loft by Spline" is what you want.
        https://www.mkaplanfinefurniture.com/
        • EscapeArtistE Offline
          EscapeArtist
          Or perhaps 2 Faces + Path?
          http://forums.sketchucation.com/viewtopic.php?f=323&t=21658&hilit=blend+path
            ryangarnett
            Thank you, that is exactly what I was looking for.
