    Using round() in a SketchUp plugin
    10 Posts 4 Posters 866 Views 4 Watching
      steve r
      Hi, I'm new here (and pretty new to Ruby, as well as plugin creation) so if this is in a horribly wrong place let me know and I'll re-post.
      In any case, I've got the following code in my plugin, and it's just not working.
      percent = 100*array[0]
      percent = percent.round(2)
      I believe it should work, as this is the syntax I saw here, but SketchUp doesn't seem to recognize it. I'm just looking to take an unwieldy float value out of an array and tidy it up to two decimal places before putting it into a messagebox.
        You haven't provided the whole picture. πŸ˜•
        Let's assume that ' array' is an array of numbers.
        You need to pass a 'float' to '.round' so try using 100.0 instead of the 'integer' 100 - that will then force the answer into a float even when array[0] is an integer...
          Jim
          Hi Steve,
          The Ruby version (1.8.6) which comes with SketchUp does not support the argument to round. This came in a later Ruby version. 1.8.7 I think. 😞
          Anyway, you can access the 1.8.6 docs from the same site: http://www.ruby-doc.org/core-1.8.6/index.html
            To add a round 'range' etc to the current version of SUp's Ruby copy/paste this into a float_extras.rb file in Plugins to add these additional methods
            class Float
              def round_to(x)
                (self*10**x).round.to_f/10**x
              def ceil_to(x)
                (self*10**x).ceil.to_f/10**x
              def floor_to(x)
                (self*10**x).floor.to_f/10**x
            =begin
            Example usage;
            num = 138.249
            num.round_to(2)
            # => 138.25
            num.floor_to(2)
            # => 138.24
            num.round_to(-1)
            # => 140.0
            =end
            replace .round with .round_to(n)
            etc...
              steve r
              @jim said:
              Hi Steve,
              That's a shame. In any case, I came up with a workaround, I suppose it's pretty obvious but I thought it might help anyone else who needs to do some rounding in SU:
              percent = (10000*array[0]).to_i
              percent = percent.to_f/100
              Just add equal numbers of zeroes to the numbers if you want greater precision. As it's written, it rounds to two decimal places.
              • Dan RathbunD Offline
                Dan Rathbun
                There is also a backport ruby gem.. that "updates" older Ruby versions with features from newer releases.
                But the weird thing is that then RUBY_VERSION and RUBY_PATCHLEVEL become meaningless.
                I'm not here much anymore.
                  Dan Rathbun
                  TIG's example WILL work, but requires that EVRYONE have that "extension".
                  You might put those methods inside a library module, inside your toplevel "author" module.
                    steve r
                    Well, does my simplified attempt at rounding above work? I only need to use it one time, so I would think it'd be faster just to do it via my method.
                      Dan Rathbun
                      No the round() function actually rounds.. the to_i() function actually truncates.
                      Use the "meat" of TIG's example in a single statement
                      .. or write methods into your module thus:
                      module Author; module ThisPlugin; end; end
                      module Author;;ThisPlugin
                        class << self  # proxy class
                          private # just to show that percent() will be private
                          def percent( num )
                            (num*10**-2)
                          public # just to show how to return to the default
                                 # of making following methods public.
                          def round_number( num, places=0 )
                            (num*10**places).round.to_f/10**places
                        end # proxy class
                        begin
                          num = 78.67812 # just for example
                          per = percent( round_number(num,2) )
                      end # module
                        steve r
                        .. or write methods into your module thus...
                        Good point! I hadn't considered that my method just truncates. I'll have to see if I can figure out a simple way to incorporate TIG's example into one statement; a lot of that code goes right over my head! Thanks for the help!
