    [Plugin] Another Sketchup Plus update v1.5.4 Dec 29 2012
    26 Posts 6 Posters 40.1k Views 6 Watching
    • guanjinG Offline
      guanjin
      Every time you start this prompt, very annoying
      • dukejazzD Offline
        dukejazz
        Function One:Editing a model: 编辑模型:
        Edit model apart [send select] to another sketchup.
        When objects changes are finished exit parent, then restart the parent model again.
        [select exit] a child.
        Select and use [replacer] to put objects back.
        When done save model.
        • guanjinG Offline
          guanjin
          Thank you, I first menu compiled into Chinese, my English is too bad
          • dukejazzD Offline
            dukejazz
            Function one makes bigger documents
            Function two makes smaller documents
            When you start sketchup it dosn't ea time start in the same amount of time. This menu help to get sketchup an another plugin to shake hands for their functional opperations.
            Another Sketchup Plus when or not in use can be turn on or off by extension pannel
            I have a by pass method but you will loose start up paste in place
            Next I will explain how to reprogram the menus for the by pass
            • dukejazzD Offline
              dukejazz
              Function Two (p1) : Braking down a models and saving a component or piece of a model 制动分离的模型
              Download
              Select a object and press[Move select] to another sketchup
              Again select a piece and press [Move select] to another sketchup
              when you find the component or piece you need.
              Save as a objects Skp
              Also
              Function Two (p2): Remove objects from models
              Remove objects from model [Move select] to another sketchup.
              Pull walls, roof and detial from model
              • guanjinG Offline
                guanjin
                Thank you, the boxes can not be compiled into Chinese??
                • dukejazzD Offline
                  dukejazz
                  Boxes
                  Bing Translator
                  Another Sketch-up Plus 1.2
                  Now pasting your clipboard information.
                  To undo placed : Press [redo].
                  other view : Press [previous] view.
                  Mac user
                  Paste, pass thru: Press [space-bar].
                  Other place [Place-in Place]
                  OK
                  另一個草繪向上加 1.2
                  現在粘貼您的剪貼板資訊。
                  若要撤銷放置: 按 [重做]。
                  其他視圖: 按 [上一頁] 視圖。
                  Mac 使用者
                  粘貼的通過陪伴你: 新聞 [空白鍵]。
                  其它地方 [地方在地點]
                  還行
                  Features list:
                  • Paste (Paste in place or paste)
                  • Replace (Select, delete and paste)
                  • Duplicator (Select sum, Copy and paste)
                  • Duplicate all (Copy all and paste)
                  • Point-axes (Mark a object outside edge-area with a cpoint: then set axis)
                  • Ruby repeat loader (load hidden script plug-ins)
                  • Explorer (Open's explorer and hide or unhide plug-ins for another sketch-up)
                  • Extension (Set another sketch-up on/off)
                  • Move select (Move select to another sketch-up)
                  • Send select (Send select to another sketch-up)
                  • Send select all (Send select all to another sketch-up. Restart Entities objects and flushes script plugins)
                  • Non selected Move (Clipboard info is sent to another sketch-up)
                  • Non selected Select (Clipboard info is sent to another sketch-up)
                  • Select exit (Copy selected then exit sketch-up)
                  • Select all exit (Copy all then exit sketch-up)
                  • Clear exit (Clear clipboard then exit sketch-up)
                  • Clear paste (Clear clipboard)
                  • Non Select exit (Keeps Clipboard then exit)
                  功能清單:
                  -貼 (粘貼在地方或粘貼)
                  -替換 (請選擇、 刪除和粘貼)
                  -影印機 (選擇筆、 複製和粘貼)
                  -重複所有 (所有的複製和粘貼)
                  -點-軸 (標記物件邊緣區與 cpoint 以外: 然後設置軸)
                  -Ruby 重複載入程式 (負載隱藏腳本外掛程式)
                  -資源管理器 (打開的資源管理器和隱藏或取消隱藏另一個草繪上的外掛程式)
                  -擴展 (集另一個草繪向上開/關)
                  -移動選擇 (請選擇移動到另一個草繪上)
                  -發送的選擇 (發送到另一個草繪向上選擇)
                  -發送請選擇所有 (發送所有選擇另一個草繪向上。重新開機實體物件和刷新腳本外掛程式)
                  非選定移動 (剪貼板資訊發送到另一個草繪向上)
                  非選定選擇 (剪貼板資訊發送到另一個草繪向上)
                  -選擇的退出 (複製選中然後退出草繪向上)
                  -選擇所有退出 (所有副本然後都退出草繪向上)
                  -清除 (清除剪貼板然後退出草繪向上) 退出
                  -清除粘貼 (清除剪貼板)
                  非選擇退出 (然後退出保持剪貼板)
                  • dukejazzD Offline
                    dukejazz
                    To edit actions and menus for your needs, do it here, in the def statements
                    SketchUp 8\Plugins\dj_another_sketchup
                    Another_Sketchup_Plus_loader.rb
                    notepad
                    ( by moving around line rem #)
                    def youSU_clearCbExit
                    [Auto PC Way]
                    $m="cmdClearCb.lnk";youSU_dj;
                    Sketchup.active_model.abort_operation;cmd=m=$m="nil";youD_exit;
                    two line[on/off #](use # to change infront of lines)
                    [Mac way ?]
                    #youD_exit;# [on/off #](remove # to change infront of line)
                    end;#def
                    def youSU_clearCB
                    [Auto PC way]
                    $m="cmdClearCb.lnk";youSU_dj;# [on/off #](use # to change infront of line)
                    [Manual way] [Mac way ?]
                    #another_clearCB;# [on/off #](remove # to change infront of line)
                    def youSU_explorer
                    $m="explorer.lnk";youSU_dj;# [on/off #](use # to change infront of line)
                    [Pc way][Mac way ?]
                    #$m="--------------?";youSU_dj;# [on/off #](Remove # to change infront of line and add brower infro )
                    end;# def Brower
                    #def youSCF_CadFather_Startup Block_(choose one mode only)
                    def youSCF_placeMain
                    [mode 1]
                    youSCF_place;# [on/off #](use # to change infront of line)
                    [mode 2]
                    #youD_paste;# [on/off #](remove # to change infront of line)
                    [mode 3]
                    #youSU_byPass;#[on/off #]((remove # to change infront of line)
                    end;# def:
                    def youSCF_placer
                    [option 1]
                    [option 2]
                    #youD_paste;#[on/off #](remove # to change infront of line)
                    end;#
                    #def youD_______ Driven______
                    def youD_replacer
                    [option 1]
                    youD_paste;# [on/off #](use # to change infront of line)
                    [option 2]
                    #youSCF_place;#[on/off #](remove # to change infront of line)
                    end;# def
                    #Main menu______You can turn off menus_____Edit it to fit your needs____(only one of the three can be active)
                    1(To make this active)
                    #=begin
                    full menu Context
                    [on/off#]
                    #youSU_contextA (remove # change infront of line)
                    #youSU_contextB (remove # change infront of line)
                    #=end
                    2(To make this active)
                    #=begin
                    full file menu
                    [on/off#]
                    #youSU_fileA (remove # change infront of line)
                    #youSU_fileB (remove # change infront of line)
                    #=end
                    3(this is active as defalt)
                    #=begin
                    split in haft (file and Context)
                    [on/off#]
                    youSU_contextA (use # to change infront of line)
                    youSU_fileB (use # to change infront of line)
                    #=end
                    #Main_________________________________________________
                    you_anotherMain;# [on/off #](use # to change infront of line)
                    (This mean manualy paste in place on each startup)
                    cmd=m=$m="nil"
                    $Another_sketchup_menu_loaded = true
                    Sketchup.active_model.abort_operation; #flush ram mem, closes jumping from and to instances
                    • dukejazzD Offline
                      dukejazz
                      I will try to give compiled instruction into Chinese to help soon
                      • dukejazzD Offline
                        dukejazz
                        by glro on Thu May 17, 2012 12:59 am
                        KISS... ("keep it simple, sir" approach)
                        I basically need only 2 options:
                        move select
                        select all exit
                        ok
                        I guess it will be the same for some other sketchup users...
                        Yes, the messagebox has been removed; it is much more convenient, at least for me
                        thank you
                        by sadyo on Sat May 19, 2012 8:14 am
                        Thanks dukejazz, it's very usefull plugin,
                        btw, I am using dj_another_sketchup Ver. 1.2a KISS options now, but how to make the toolbar appearing again like when I'm using Another Sketchup ver 1.2?
                        I'm no see it in View > Toolbar
                        dukejazz
                        I turn on toolbars put pound sign in front, like this #=begin and #=end below in this file loader
                        Plugins\dj_another_sketchup\Another_Sketchup_Plus_loader.rb
                        Its now a new update
                        Another Sketchup plus ver 1.2a (toolbar ver)
                        • EdsonE Offline
                          Edson
                          james,
                          you plugin seems to be very useful but it lacks a video that illustrates clearly what it can do. I have some difficulty myself to grasp all it offers. some kind of general explanation of all its features would be of benefit to all members.
                          http://www.mahfuz.arq.br
                          • dukejazzD Offline
                            dukejazz
                            I still need to make a demo movie
                            I fix the box problem, no more message need.
                            I move the Hints: by dukejazz in the making of Another to here
                            Hints:
                            Some Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus Ver. 1.2
                            1 You can manually (flush a clipboard) of entities clean: By Using 3d text tool and copy a leter of text Then [cancel] out.
                            2 Another Sketchup plus has a (auto clearing clipboard) useing a shortcut Cmd.link script to clear clipboard. I tried to make a ruby API script but failed. Cmd.link clean better than the manual way.
                            3 (Security reasons): Flush clipboard when you leave your work area.[Clear Exit]
                            4 (Never loose a documents) Make use of making copies of your document in your brower.
                            5 (Smart) Open brower's copies to rework on keeps you from saving back to original.
                            6 (Limits gray-out) Keep startup and console loaded plug-ins to small and few.
                            7 (Keeps Skp file size small) In model, components and materials: uses (Via) Save and purge.
                            8 (Watch memory flow:) Task manager: It is normal for parents overhead memory to be larger than a child.
                            9 (Large doc gray-outs) Open a new parent copy of the document to paste back into it, because of larger overhead of note 8.
                            10 (Max File save size) Max file size is by power of zoom extents, and by zoom in/out decreases the save size?
                            11 (Polyreduce if you can) Overworking objects gives higher code counts. Keep objects hollow. Delete unused or unneed lines.
                            12 (Bug splats) Keep register clean. Delete extra ToolbarsUser-Bars and ToolbarsUserCustom-Bars, If you get to 1000 it will splats on you, also it will take away loaded memory space too.(slows runway Bug splats)
                            HKEY_CURRENT_USER\Software\Google\SketchUp8.
                            a (Find) ToolbarsUser-Summary and ToolbarsUserCustom-Summary.
                            b (via) Right-click_ permission special _ to you full control on and you read off. This (Locks) Toolbars to fix num ToolbarsUser_limits overloading your registers.
                            13 (No need to load rbs at start up} By using a Sketchup::require statement, in a rb, you can loads a rbs scrip to the ruby console.
                            14 Fix your start up rbs code to zero by via note 13. Another Sketchup Plus Ver. 1.2 will run as a ruby console script a
                            • dukejazzD Offline
                              dukejazz
                              new
                              5/20/12
                              Another_Sketchup plus Ver. 1.3
                              fix messagebox hand shake problem has been removed
                              rename some features to better fitting names
                              full functions context_menu
                              updated extension info
                              • cmeedC Offline
                                cmeed
                                not quite sure i understand the functionality of this plugin - a video would sure help
                                is this like 'edit in place' plugin from the podium guys?
                                c
                                • dukejazzD Offline
                                  dukejazz
                                  by cmeed on Mon May 21, 2012 1:02 am
                                  'edit in place'
                                  EditInPlace is a Google SketchUp plugin that lets you edit (modify) components and groups in a separate Google SketchUp instance.
                                  Went to their web site today and copy their decription above.
                                  by dukejazz on May May 21, 2012 8:39 pm
                                  I not sure
                                  I would say no
                                  Mine has more functions and is a platform
                                  Mine is like a 3 function mouse to their one fuction mouse.
                                  Their work with auto paste in place back for the MAC and Pc
                                  My manual paste in place coded dosn't work on MAC
                                  I use the functions of API to run another Google SketchUp instance.
                                  Started my develpment in dec 2011 indepentantly with out referance to podium guys?
                                  paste in place method _____________________________________
                                  Reference helped by CadFather
                                  cd_standard.rb on Fri May 22, 2009 toolbars structure and paste in place coded
                                  Need a movie
                                  by guanjin on Mon Mar 12, 2012 12:12 am
                                  by Edson on Sun May 20, 2012 7:36 am
                                  WIP
                                  My outline of my movie to come and the plugin another sketchup plus functionality:
                                  What is this plugin about, its a
                                  Project platform Editor: ( with plugins management and pasting tools )
                                  • Auto loads another sketchup with clipboard information.... Gives easy power functionality actions, to the editing of sketchup models, objects, or entities;... The objects can be pull out to a child sketchup and return back to illustrations detail to main project when done.
                                  -Help the loading of ruby scripts plug-ins. With ruby repeater installer, you can load plug-in scripts from main pulgin ... when you need them, ..... This gives you more than a 1000's chose's to choose from.
                                  -You can also reinstall plug-ins (in and out with hide/unhide method) by the brower .... then sending all objects to another sketchup will flushes all ruby in console out when new child sketchup starts......now you can do more ..... and manage gray outs memory limits.
                                  • Pasting tools I provide here are these paste in place, Duplicate, repaste, cpoint axes and clipboard cleaner
                                  • cmeedC Offline
                                    cmeed
                                    Su podium edit in place - http://www.suplugins.com/edit.php
                                    where did you see your 'edit in place'? Interested to know...?
                                    c
                                    • dukejazzD Offline
                                      dukejazz
                                      'edit in place'
                                      Went to their web site and copy their decription
                                      May 23 full decription
                                      Click Here to view a quick YouTube video of EditInPlace.
                                      EditInPlace overcomes one of Google SketchUp's biggest limitations - the clipping plane which prevents you from effectively editing small components in large models. It is a time saver for SU Podium users who need to add properties to materials that are hard to find in large models.
                                      I not and expert on their program
                                      Your place is the same Place I when too (I google it.to see what you ment by 'edit in place')
                                      Then I view their small quick YouTube video of EditInPlace.
                                      My development came from my tips
                                      http://forums.sketchucation.com/viewtopic.php?f=79&t=40254
                                      Tips about running more than one Sketchup
                                      by dukejazz on Thu Sep 22, 2011 1:17 am
                                      5 tips about running more than one sketchup
                                      Tip 1) Run and do more with sketchup
                                      You can run more than one sketchup programs at the same time.
                                      Just hit your shortcut key twice and find out.
                                      Tip 2) Cut and paste or paste in place
                                      a) You can cut and past between between same levels of sketchup programs. 8-8 7-7 6-6
                                      b) There are some copy programs that can copy many levels of copys with sketchup (25 level+ or more) M8 Free Multi Clipboard: Free Clip, Spartan Trial Upgrade
                                      Tip 3) Use each sketchup for different task
                                      Use one for laying out and other for creating the object.
                                      Tip 4) Toolbars behavior
                                      a) Remembers the last program exited is how the toolbars will look when you restart.
                                      b) Common view can be saved by saving view - toolbar - saving toolbar positions.
                                      Tip 5) Can use more plug-ins folders
                                      a) By copying sketckup 8 to another location, you can load more plugins.
                                      b) Also a empty plug-in folder is a great viewer
                                      c) For zone testing for new downloaded plug-ins
                                      (hint)
                                      a) When copy is completed, make a new shortcut (sketchup2) to new sketchup.exe.
                                      b) Load new plugins with a ruby toolbar.
                                      c) Clean your registers, when needed.
                                      All of this will help to over come the overloading of gray outs and bug splat.
                                      (6 tips) for a better sketchup 8 m2...........pg 2
                                      I made a plugin to make you life easier to control another sketchup
                                      my tips that I posted here as help me to write this plugin.
                                      History of the plugin
                                      [plugin] Another_Sketchup v1.0 Dec 28 2011
                                      [plugin] Another_Sketchup v1.1 Jan 18 2012
                                      [plugin] Another_Sketchup plus v1.2 Jan 31 2012
                                      [plugin] Another_Sketchup plus v1.2.1 feb 2 2012
                                      (14 tips ) Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus ...........pg 2
                                      My latest changes are user request to fit their needs.
                                      Podium guys direction is a rendering Editor: for materials properties
                                      Mine is a Project Editor: for engineers (red line note pad).
                                      I see you have a MAC
                                      I can set up a ver that paste only if you want.
                                      I here to help.
                                      -dukejazz
                                      Download:
                                      v 1.3 MAC bata
                                      Let me know, if this works for you.
                                      • cmeedC Offline
                                        cmeed
                                        I'm off on holiday for a couple of weeks, sorry. Maybe when I return. The latest info tells me more about how your plugin works I understand a bit more. You really need to do a video to get a full understanding.
                                        • dukejazzD Offline
                                          dukejazz
                                          new
                                          6/4/12
                                          Another_Sketchup plus 1.4 Bata Project Editor
                                          fix timing issue w/dj_delay
                                          added scale and move tool
                                          updated extension info to 1.4 Bata Project Editor
                                          • dukejazzD Offline
                                            dukejazz
                                            Update:
                                            7/23/12
                                            • edited Another_Sketchup Plus Ver. 1.5
                                            • took out Another_Sketchup Ver. 1.5
                                            • took out scaling
