    Zippo Lighter
    Scheduled Pinned Locked Moved Organic Modelling
    40 Posts 8 Posters 24.1k Views 8 Watching
    • HumpmetwiceH
      Humpmetwice
      This is what I have so far.
      Zippo Parts.skp
      • soloS
        That's gonna be a tough one to model IMO,especially the edges as you already have thickness modeled. gonna be interesting, keep us posted, I'd have gone for an easier one like this:
        http://www.arizonacustomknives.com/images/products/21840-1.jpg
        • HumpmetwiceH
          Humpmetwice
          Might have to Solo cause things don't seem to working out for me at the moment!
          • iichiversiiI
            iichiversii
            Model the skull on a flat mesh, then use shapebender to paste it onto your lightersurface , it's really not that difficult, if your not sure if shapbender there are great tutorials on how to use the plugin, 😄
            Bring on the Rain...
            • HumpmetwiceH
              Humpmetwice
              I tried using shapebender and maybe I'm doing something wrong but it seems to stretch it out some. I will keep tryingand look again at the tutorials. Thanks
              • iichiversiiI
                iichiversii
                Did you try reducing the scale before using sharp bender so when it wraps around the stretch would be more suited then, can you post an image as to how stretched it is?
                • HumpmetwiceH
                  Humpmetwice
                  Working on it now and it may take a while but I will post it when I done.
                  • iichiversiiI
                    iichiversii
                    That would be great, if you need any help with it get back to me and I'll have a look at it for you
                    • HumpmetwiceH
                      Humpmetwice
                      Another problem I keep having is when I use shapbender, is when I try bend the bones not the skull, sketch-up crashes. This is the set-up and it's scaled way up. I got the skull and crossbones from the warehouse and spent a lot of time making them solids so I don't think thats the problem although it is a quite large file.
                      • numbthumbN
                        numbthumb
                        Bedning such a model could be a bit tricky, don´t know if it´s gonna work 😕
                        The skull in that image you posted is "flattened". How about Tools on Surface + Joint Push Pull?
                        Comfortably numb...
                        • iichiversiiI
                          iichiversii
                          Ok your going about this wrong, look at the image of the lighter, the skull and bones wiuld be flat if not wrapped around the main lighter, that's how the skull and bones need to be modeled to be wrapped around your lighter, at present I'm not in front of my laptop but if I were I'd model the skull and bones for you, I will try tonight, do you understand what I mean about the flat surface, look at the skull your trying to use, it's curved, so shape bender can't do what your asking it to do, do you need help with modelling the skull and bones onto a flat surface? I can do this for you and have it posted up tonight
                          • HumpmetwiceH
                            Humpmetwice
                            Yes it would be very nice of you to model the skull and crossbones because I am stuck!
                            Thanks Kurt
                            • numbthumbN
                              numbthumb
                              This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:lighter.jpg
                              Comfortably numb...
                              • HumpmetwiceH
                                Humpmetwice
                                @numbthumb said:
                                This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:[attachment=0:1bihddj8]<!-- ia0 -->lighter.jpg<!-- ia0 -->[/attachment:1bihddj8]
                                That looks about what I want but I can't draw a nice enough skull& crossbones!
                                • iichiversiiI
                                  iichiversii
                                  @numbthumb said:
                                  This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:[attachment=0:40xardmy]<!-- ia0 -->lighter.jpg<!-- ia0 -->[/attachment:40xardmy]
                                  What Numbthumb has illustrated here explains everything iv said, notice how the skull is flat like the images you posted and not like the 3d skull you were trying to use, obviously Numbthumb only put up a quick illistration and more detail like in the images you provided can be added to your model, even before you use shape bender, using the skull and crossbones would not have worked, does this put it into perspective for you? If your not sure ask and I'll explain it further for you with more tuts
                                  • iichiversiiI
                                    iichiversii
                                    @numbthumb said:
                                    This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:[attachment=0:2b38ohpy]<!-- ia0 -->lighter.jpg<!-- ia0 -->[/attachment:2b38ohpy]
                                    You don't need to draw it of the tip of your head, download an image and import your image into sketchup and simply trace out the skull and crossbones
                                    • HumpmetwiceH
                                      Humpmetwice
                                      Ok this is what I finally have but still can't manage to get the skull to curve around without it stretching.
                                      Skull Zippo-1.skp
                                      • iichiversiiI
                                        iichiversii
                                        Ok iv run into the same problem with the stretch, ill play around with it more and see what i can do 👍
                                        • iichiversiiI
                                          iichiversii
                                          ok heres my suggestion, and it worked for me, after ou get your shape bended stretched version move it up to the original and match up on each other, note where the stretch/bend takes place and slice the original into too parts on that line, with the left side rescale it to 1/4 sizeand reconnect the original, now it may look wrong but shapebend it again and theres your result 😍
                                          • HumpmetwiceH
                                            Humpmetwice
                                            Not sure if I understood you right but what I did still made no difference.
