    Old Afgan ruin
    33 Posts 8 Posters 5.6k Views 8 Watching
    • H Offline
      Hussel Hann
      what you've done really amazed me. 😲
      ...because I have no idea how u build the wall. looks like u model the brick one by one and put them together and then smash it with a SWAT's metal ram using Sketchy Physics. I really want to know how u create that openings.. πŸ€“
      Thanks!!!
      • mitcorbM Offline
        mitcorb
        Good job on first image. I actually like the feel of the scene as is. Maybe the timbers are popping out more than you might like.
        • iichiversiiI Offline
          iichiversii
          Thanks!!!
          Ok ill give a quick tutorial to ow i did it, not sure if its the only way it can be done but this is my workflow.
          First i build the house first with out any flaws, in this image under you will notice the building on the left has no flaws with stone work but has with the woodwork, ill show you a quick tutorial with this also.
          Once i have the building made i remove each wall which are all saved as seperate groups or componants, i the use the line tool to trace out sections of stone i want to remove as illustrated in the image below.
          And to create the weathered timber look under you will find another tutorial.
          Bring on the Rain...
            iichiversii
            Sorry i should of mentioned, my models are based on a cartoon war game, i over exagerate in my models to add to the look and feel of the game, glad you like it thu πŸ˜„
              iichiversii
              Heres a little more added to the scene, not finished yet, more to be added, I would like to point out the pallets, the pallet is a tutorial in Robin de Jonghs book "google sketchup for game design" fantastic tutorial and if you have issues with texturing in SU you wont after doing the pallet tutorial, thats for sure, the book is great but im running into problems with some parts but thats due to my lack of knowledge of using Gimp and Unity3D, will add more to this scene in the next few days, πŸ˜„
                Roger
                Have you looked at the histograms of your images? The histograms are so dark that in some of the images, I can not see the buildings at hall. Had to take them into PhotoShop and redo levels just to confirm there is an image.
                http://www.azcreative.com
                • H Offline
                  Hussel Hann
                  Thanks for the tips and tuts Damien..
                  Appreciate it so much..
                  Thanks!!! ( πŸ‘ x 100)
                    iichiversii
                    I'm sorry I didn't relise, the brightness is so high on my comp it looks fine but I'll bare that in mind in future, cheers for the heads up 😳
                      iichiversii
                      No problem at all Hussel, I'm only glad to help out, if you need anymore help sure get back to me, hope the tut was clear and concise, πŸ‘
                      • pbacotP Offline
                        Funny the settings can be so different.
                        The images look more detailed on my screen like this:afghan.png
                        and it's a cool technique. Trying to see how it can apply in other models. Thanks!
                          iichiversii
                          Thanks Peter, glad you liked it, will post up a better image at some point today, i find your image very bright, maybe its my comp but we will see with the next image, ill get working on it with more added detail πŸ˜„
                            iichiversii
                            Ok here are a few more images with lighting improvments, also some close ups to enthisize the detail of the pallet and the stone work, let me know if these images are too dark, ill redo them again. πŸ˜’
                            • pbacotP Offline
                              Looks good! It still has a certain darkness and redness, like an overcast dusk, but that may be what you're after. a very quiet mood. Where'd all those palettes come from?:enlight:
                                iichiversii
                                It's exactly the setting I was looking for, the pallets is a tutorial in the book "google sketchup for game design" I only got it last wk and tried out the tutorial, fantastic tut on how to create a pallet with the right texture applied, took just under an hr to complete but it taught me a lot on texturing in SU
                                  iichiversii
                                  I'll post the pallet skp file tomorrow, I won't be giving a tut on it as its in the book I mentioned and it just wouldn't be fair on the author, I strongly recommend this book, helped me a lot in understanding textures and creating textures
                                  • H Offline
                                    Hussel Hann
                                    Simply Wow!
                                    The terrain is blur on the last image. Is it due to the texture resolution?
                                    One more thing sir, is there any reason why the terrain is not looking "alive" like the bricks? (No bump)
                                      iichiversii
                                      I haven't worked on the terrain yet, only the building and props, will work on the terrain later πŸ˜„
                                      • E Offline
                                        Ecuadorian
                                        Thank you, Damien. Nice tut! πŸ‘
                                        -Miguel Lescano
                                          iichiversii
                                          Your welcome, if anyone is doing something like what iv showen in the tut feel free to post your image here, and if you would like to add to it I would like to hear it here too, I'm not perfect, cheers again
                                          • H Offline
                                            Hussel Hann
                                            Hi Damien...
                                            After seeing your tips & tuts, here is what I came up with. A Smurf's house.
                                            Still pretty rough + my hand is not sturdy enough when using "free hand" tool to create those rough wood effect.
                                            Looking forward for your next masterpiece...
