    [Plugin] Taper Maker v1.3.5 - Apr 2012 Update
    3 Posts 3 Posters 4.4k Views 3 Watching
      max-cx
      Two new taper (extrusion) cross sections were added to TaperMaker: right trapezoid and quadrilateral.
      To create tapers using these cross sections, you must select two paths (rather than just one). The base of the cross section will follow between the selected paths, and the width of the base will vary with the distance between the paths.
      Here is an example of some tapered right trapezoids:
      A demonstration video (3:20) is available at: http://youtu.be/4Erlpw22F7o
      You can download the plugins from: http://www.drawmetal.com/download
      Terry
        driven
        hi
        looks great, i'll give it at spin when I get some time.
        thanks for your generosity
        • utilerU Offline
          utiler
          Well done, Terry!!!1 Although its not something I use often it is a very well put together toolset!
          πŸ‘ πŸ‘
          Just Curious...
