    Does this plugin exist? (select and hide only the lines)
    3 Posts 3 Posters 232 Views 3 Watching
    • E Offline
      errror404
      Let's say I have an object that I want to hide the lines (without hidding the faces)...
      My only option is to select each line individualy and hit hide. Any other ideas?
      Soften edgesor making a custom style are not an option.
      I want crisp 90* angles (but no lines) so soften edges is not an option. I also want the rest of the model to show lines... so a custom style is not an option either.
      thanks
        Aerilius
        "Select only β†’ Edges" and then hide (as before).
          Phil Rader AIA
          Just another option Make a new layer called Lines >>> go to wire frame mode >>> Select all the lines you want to hide >>> Then with the Layer dialog put them on the layer called lines >>> now return to shaded with textures or what ever style you want >>> then turn off (un-check visibility)for the Lines layer...
          The nice thing about this method is that the lines are not actually hidden just the layer. This will give you more flexibility and ease of use since you can turn the lines on and off easily by just selecting the visibility of the lines layer.
          Just my 2 cents worth.
          http://www.philrader.com
