    Preventing Divide by Zero, problem with IF?
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 2 Posters 514 Views 2 Watching
    • F Offline
      FlobRob
      Hi All
      I'm a comparative newbie to sketchup and complete newbie to this forum. I have searched this forum as best I can and have found a couple of other people who have a similar problem but no solution. I'm hoping someone out there has worked this out.
      I have a simple component with a single custom attribute - angle.
      I then use LenX/TAN(angle) to work out LenY
      This works fine except when angle=90, because TAN(90) is undefined.
      In this case I would like to set LenY=0
      So I tried something like
      LenY = IF(angle=90,0,LenX/TAN(angle))
      and
      LenY = IF(angle<90,LenX/TAN(angle),0)
      In both cases sketchup evaluates the part of the IF statement not required and causes an error.
      I have solved this problem by evaluating the other angle in the triangle
      ie
      LenY = LenX*TAN(90-angle)
      but I wonder why the IF method didn't work and if anyone out there has any alternative methods to implement this sort of defensive programming to prevent divide by zero
      IF(attrib1=0,0,attrib2/attrib1)
      I know others have the same problem, surely this should be easy
      anyway thanxs in advance, I love Sketchup and this site looks great!
      • DareDevilD Offline
        DareDevil
        Hello,
        I had the same problem with a A/sin(B) when B = 0.
        I turned and turned to found a solution...
        Look at this thread
        • F Offline
          FlobRob
          daredevil
          yeh I saw your bridge, very impressive work. My models are a lot more humble but I aspire to create complex dynamic components. That is the reason why I would like to find out how to do these things nicely and elegantly.
          I presume the IF problem we both had is a problem with the way sketchup parses the IF function. I have a little experience with C++ from 20 years ago and would have expected it to work.
          Anyway I am wondering if I should learn Ruby and if these sort of things can be done in that. I am frustrated with the way you enter formulas in the dynamic component attributes dialogue, it works fine for simple components but it is difficult to read complex nested functions in such a small text box. Sometimes I have resorted to copy/paste into notepad, and use indentation to help match parenthesis and make it clearer and then copy/paste back. It would also be nice to be able to add comments.
          From seeing the bridge you've made you're obviously well ahead of me. I would like to produce fully configurable pieces of furniture and joinery for my business. Do you think I should persevere with Dynamic Components or will I discover that their limitations mean I should learn the Sketchup Ruby API?
          Again very impressive work you do, it would give me a real kick to produce something half as good as that ☀
