    What is that sketching program
    10 Posts 6 Posters 901 Views 6 Watching
    • pbacotP Offline
      One of the 3d sketching programs I've seen in the past couple years: as you sketch consecutive lines, the program refines the line you are working on. It has symmetry and other 3d features. I am sure someone posted a link on Sketchucation. I'd like to find something like that in iPad--or even just a 2d napkin sketch (in scale) with layers, for quick sketching functions.
        This one ?
        [flash=420,315:sklcr8wv]http://www.youtube.com/v/hSxCZE6PG50[/flash:sklcr8wv]
        • pbacotP Offline
          That's it. Cool. Thanks Pilou!
            Not sure that you can find the same on Ipad ๐Ÿ˜‰
            • brookefoxB Offline
              brookefox
              Well that's cool. I was looking for the HW req's and couldn't really find anything. Quite early in the devel process, I guess, though it has been around for awhile.
              http://www.dgp.toronto.edu/~shbae/pdfs/Bae_Bala_Sing_2008_ILoveSketch.pdf
              ~ Brooke
              • pbacotP Offline
                I don't think it's available at all yet. I am trying sketching early floor plan ideas on Sketchbook and it's OK for some quick 2d ideas. Easy to draw and erase quickly.
                • HieruH Offline
                  Hieru
                  That is very very cool. If they could take that and apply it to solids it would revolutionise 3D modelling.
                  www.davidhier.co.uk
                  • KrisidiousK Offline
                    Krisidious
                    SketchBook from Autodesk allows one click refine of line and back to as drawn.
                    http://usa.autodesk.com/adsk/servlet/pc/index?id=6848332&siteID=123112
                    By: Kristoff Rand
                    • pbacotP Offline
                      Kris,
                      I have the iPad version (learning it) and I haven't noticed it in there. But quick switching between eraser and pencil is helpful. I am sketching over an existing plan. I add a layer and spray brush white to obscure areas to be reworked, and other layers to try different layouts. No scale except the one in your head.
                      Peer
                        johnsenior1973
                        Autodesk Sketchbook Pro is purely for 2D sketching and painting.
                        Autodesk Sketchbook Designer is the more complex application where you can make massive edits to everything.
                        Autodesk Alias combines 2D drawing and 3D modeling.
