    Raster to Vector Conversion... any new advances?
    15 Posts 7 Posters 2.1k Views 7 Watching
    • dukejazzD Offline
      dukejazz
      I use RasVector.exe converter because it free an fast
      http://dan59314.myweb.hinet.net/IndexEn.htm
      jpg to a ink dxf
      Inported to sketchup
      Now this where the problem starts
      What you are asking then is there a Ras-Vector clean up line restorer?
      Ink dxf creates a raster line
      ❓ help, I like to know too.
        I've given up on this already. It's like laser scanning vs. taking manual measurements and building the footprint yourself (a bit referencing to this topic, too). By the time you process your data and can start cleaning it up (which, at a first sight looks a task worse than redrawing that image from scratch in SU), you are so frustrated that you wish you'd never even heard of raster to vector "scams". 😄
          mac1
          [here are some results:
          Test raster _vector.skp The skp file is not usable.\My license for WinTopo expired so did this with free version.
          The jpg you posted has a number of problems:
          1. It is a JPEG and it should have been save in a better format; sample size probably too large( I would probably try to interpolate: typical ACAD problems, many overlaps, some speckle. To do what you want would require some pre processing to clean the images
          2. Here are some of the results of the GIMP edge detection:I had to interpolate to allow post here
            attachment=0]MainFlrII-Edge Detect down sample.jpg[/attachment]
          • KrisidiousK Offline
            Krisidious
            yeah these are the same issues I come up against. I have other formats and have had no success with any of them. .bmp and .tiff and .tga
            and you're right that more detail seems to be a detractor instead of a helpful quality.
            Adobe illustrator seems to be the most powerful I've seen but none really get the job done.
            By: Kristoff Rand
            • pbacotP Offline
              Send em to China? (the pictures to be redrawn in CAD)
                Krisidious
                that really would be the fastest most cost effective thing to do. lol...
                By: Kristoff Rand
                  mac1
                  Will not give up yet. With all the advances in imaging technology, both over head and medical, one would think some thing is out there. GIMP uses canney, sobel and lapacian algorithms plus some others to detect. WinTopo has some too. Will have to see??
                    mac1
                    raster _vector_GBa.skpA baby step. How does this compare to your best case?
                    Clean up now using Meshlab or some plugins?
                    • charly2008C Offline
                      charly2008
                      I've tried a few programs. The result is always dependent on the quality of the scanned plan. Without manual work you will hardly get good results. I think that even the professionals do not get along without manual work. The plans for these examples are JPGs from the Internet. I found a program which provides possibly good results. The name is: Vextractor x64. It should be tried once.
                      Raster to Vector Conversion Software Vextractor. Vectorize Your Images and Photo.
                      (www.vextrasoft.com)
                      JPG in Vextractor
                      DXF in Sketchup
                      Untitled.skp
                      Untitled.skp
                        Krisidious
                        that seems to get pretty close. I'm going to play around with it.
                        By: Kristoff Rand
                          Glenn at home
                          I agree, it's just easier to start from scratch. Something good for an intern to do 😉
                            mac1
                            What Charly posted looks good and conversion to dae and then to MeshLab looks OK also=> for quick check.
                            Suggestion: Contact the seller and see if they will convert your posted test jpg since you may be interested in buying a license ? => just as an eval. test. My guess they will want you to re-scan that image to tif , not re-sample. The key to success is to have a clean image to start and if you have a number you want to convert you will have to factor that into your plans. If you can get to a somewhat decent SU ( then Dae) then Meshlab may be used to remove T vertices etc. I could not clean you ordinal test jpg to a clean level to work with.
