    Podium exterior
    29 Posts 10 Posters 6.1k Views 10 Watching
    • RichardR Offline
      Richard
      Would love to see some blender trees )in another thread obviously) Michalis! I use ONYX which is a bit hard to get head around but it builds GREAT TREES!
      BUILTBRAND.COM.AU
      • pugz1983P Offline
        pugz1983
        Hi Everybody,
        Like the render Tom. Some of the best work I've seen with Podium. I also struggled with the trees/grass and plants problem and SU, and after a long period of trail and error and a lot of bugsplats and a SU that freezes I......... decided that SU is just not suitable for this type of things. The way to go is a workflow with another main compositing 3D software pack like Blender, Cinema4D or 3DSMax. I do my modeling in SU as far as I can. Then I export my model and import into blender for example. Grass, trees and plants are easy to import into model now. You can use plugins to spread grass or use hair particle system to create grass. Blender and other programs can handle Xfrog, Onyx strees for example and when using instancing the size of models won't be a problem. The only thing that takes time is finding the right mix of apps in your workflow that best suite you and the type of work you do.
        PS: I forgot to mention Vue. Vue is very capable for creating nature elements like trees, grass shrubs and plants.
        Greetz Twan
        • michaliszissiouM Offline
          michaliszissiou
          The big problem with SU is that it can not import huge meshes. Huge? Not really, we're talking about >64k tri meshes. And trees need ~100-300K.
          To split into groups isn't a very promising method either. More complicated than helpful.
          Blender integrated tree generator is fine. There's also the excellent ngplants open source app.
          http://yorik.uncreated.net/greenhouse.html
          http://ngplant.sourceforge.net/#downloadanc
          @Richard
          Of course, but on what topic? It has nothing to do with SU .
          BTW for 2d cutout lovers. Have you tried this?
          http://arnaud.ile.nc/cantree/generator.php
          • StinkieS Offline
            Stinkie
            You're right, obviously. Still, one cannot keep buying and learning new software. ๐Ÿ˜„
            • DanielD Offline
              Daniel
              Beautiful image, Tom.
              FYI, the building is real. It is called the Delta Shelter, and was designed by Tom Kundig of Olson Kundig Architects, and has been published numerous times. http://www.olsonkundigarchitects.com/Projects/38/Delta-Shelter
              My avatar is an anachronism.
              • StinkieS Offline
                Stinkie
                Thanks for the link. I quite like that building -I'd not mind living there.
                This picture is way prettier than my render:
                http://www.olsonkundigarchitects.com/gallery_cache/38/430_380/Delta-Shelter-TB-056.jpg
                • RichardR Offline
                  Richard
                  Yeah I'm like Tom - having to learn new apps is a pain for one and then adding new steps to workflow is another! Personally I'd like to take out steps from workflow!
                  @Michalis - WOW mate, those Blender plants are THE BOMB! OMG! Start a thread in the corner bar, that's what it's for!
                  @Tom - BTW mate, just noticed the reflections on the upper story right facing windows seems weird when you should be seeing reflected sky from such a low placed camera.
                  I don't know if Podium supports Proxies, they help a bundle. These plants I created in SU although not high poly so I can spread them around, are still poly loaded enough to slow SU down if you turn their layer on before export. Proxies help by way of keeping one instance on a hidden layer and populating with a scaled proxy which then contributes very little load on SU!
                  These days with FIRE for real time material, camera and light tweaking I've just about done away with Photoshop post pro excepting for background replacement, CYMK conversion, and image resizing. And as the pluin developer is currently rewriting the plugin to support xrefing of high poly MXS files for SU proxies on export I'll also be done with Maxwell Studio. Meaning ALL work will be direct from SU with limited PS post pro!
                  BUILTBRAND.COM.AU
                  • StinkieS Offline
                    Stinkie
                    Yeah. ๐Ÿ‘
                    There's some really big trees in that garden, Richard!
                    Nope. The app's pretty bare bones.
                    • srxS Offline
                      srx
                      Great job. U can use Kerkythea xfrog trees library in Thea.
                      www.saurus.rs
                      • pugz1983P Offline
                        pugz1983
                        After find a way to use high poly plants and trees there's another challenge awaiting. How to figure out what plants and trees go together. When just throwing in a bunch of trees and plants won't make it look good. I'm always struggling with the way plants and trees grow and are arranged in an axterior scene. But I guess that it's just a case of studiyng the nature around you.
                        Greetz Twan
                        • StinkieS Offline
                          Stinkie
                          Or ... you could say "to hell with plants". ๐Ÿ˜‰ Indigo version:
                          • EdsonE Offline
                            Edson
                            TomDC aka stinkie elsewhere? ๐Ÿ˜ฎ
                            edson mahfuz, architect| porto alegre โ€ข brasil
                            http://www.mahfuz.arq.br
                              michaliszissiou
                              A wonderful design Tom!
                              I never saw an indigo render that I didn't like. I admit this.
                              About the podium render. I still admire how you handled the reflections on windows. Well done. ๐Ÿ‘
                              • StinkieS Offline
                                Stinkie
                                It isn't mine. I wish it was, though!
                                Indigo is very good. It's slow, as you'd expect, but it's lighting is superb.
                                Yep. Hi, Edson!
                                • marked001M Offline
                                  marked001
                                  the indigo version is amazing! noooowww...let's see you replicate that in podium ๐Ÿ˜„ you can do it.
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • StinkieS Offline
                                    Stinkie
                                    lol. As much as I like Podium, it isn't capable of doing this. Maybe someone who's an absolute genius at using Kray (the engine Podium uses) could pull it off, to some degree, but that someone surely isn't me. I would like to see whether I can do this with Vray, though.
                                    • StinkieS Offline
                                      Stinkie
                                      First Vray version. Everything needs more work, but it's a decent start, I think.
                                      • StinkieS Offline
                                        Stinkie
                                        Second version.
                                        • RichardR Offline
                                          Richard
                                          Yeah Tom I'm all up for the last few in preference!!!!!! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                          Not only do your works there look brilliant (well done mate) but this style is "Show All"! Nothing is padded with the excesses and trickery - just the built for displaying it's attributes.
                                          ALL RENDERS OF ARCHITECTURE SHOULD BE LIKE THIS! (yep yelling!).
                                          BUILTBRAND.COM.AU
                                          • StinkieS Offline
                                            Stinkie
                                            Thanks, Richard. Er, don't you always yell? ๐Ÿ˜Ž
