    Archeology, 3D and photogrammetry?
    42 Posts 10 Posters 7.4k Views 10 Watching
    • GaieusG
      We use quite a lot of measuring tools here (from ground penetrating radar - whose result would be something similar to those sonar measurements) to laser surveyor tools - not photogrammetry however. It could probably be useful but (currently, at least here) extremely expensive. And with cheap labour force in this part of the world, it is easier to employ a bunch of surveyors and draftsmen (most of the times just self made ones who have been working on excavations enough to know the tricks)
      As for 3D models in general: it is mostly for the same purpose arch-viz people are making these models all around here. To allow the "client" (in our case more the general public) to be able to visualize something that otherwise does not (yet / or in our case any longer) exist. So it is not too much for the "research" part of the job but the "exhibition" part.
      • mitcorbM
        mitcorb
        You could dig around in the Extensions and Applications subforum. Pardon the pun. We have seen some interesting modeling tools based on photography that generate models posted. I almost said unearthed. 😉
        • B
          bjornkn
          Thanks Csaba 😄 I don't know what is considered expensive, but I would think that a combo with SketchUp and tgi3Ds PhotoScan wouldn't break any budgets? Or wouldn't it be considered serious/professional enough, because it is too cheap? In this country most archeological sites are closed after a while, and then there are no more measurements to be taken. With a 3D model you could keep on working measuring even after the excavation is finished. Wouldn't that be desirable?
          Most arch-viz is made before the building is built, to "sell" it in advance.
          Would you say that the most useful aspect of 3D in archeology is to show things before they were ruined? For reconstructing buildings, pottery etc? Rather than making 3D models of how they look today?
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            Maybe this will interest you:
            Fastly error: unknown domain 151.101.64.81
            (www.bbc.co.uk)
            Just ideas.
            • mitcorbM
              mitcorb
              That IS amazing.
              • charly2008C
                charly2008
                I can only speak for Germany. The archeology among the other sciences, is still treated like a stepchild. It costs a lot of money and does not generate money but only cultural knowledge. In the end it's always a question of cost. If you are saving costs with special techniques, they are also used. Here in Germany there is an archeology agency for each state. And then there are the lower archaeological authorities that are responsible for the cities and counties. These agencies are usually not equipped with huge budgets and sufficient staffing. If special techniques such as laser scanning, aerial photogrammetry or building photogrammetry, 3D reconstruction are necessary, these operations are outsourced to private specialist firms. Even excavation will be partially outsourced to private specialized firms. The focus is always on the cost, the need for and benefits of specific techniques. In most cases the use of special techniques will be limited to a few very important Projects.
                • B
                  bjornkn
                  I'm sure such techniques as aerial photogrammetry, LIDAR, aerial ir scanning (like that linked to above) etc will be very costly. What I was thinking would be a very good tool, and a fairly cheap one, would be "low-altidue aerial" photogrammetry. IOW using a pole with a camera, and then make a textured 3D terrain model from the excavation site, which I would think would be very useful for comparing different layers, measuring anywhere on the site etc.
                  And then that terrain could also be used as a base for reconstructing any ruins/buildings there.
                  In Norway most buildings were built from wood, so there are usually very little left of them if buried in the ground. They usually only find the remains/holes where the corner poles were dug into the ground.
                    museummaker
                    Seeing beneath Stonehenge
                    http://www.pasthorizonspr.com/index.php/archives/01/2012/seeing-beneath-stonehenge-revealed
                    • pbacotP
                      It seems just as valuable to use 3d to record current ruins like this architect has been doing: http://www.dennisrhollowayarchitect.com/VirtualRealityArchaeology.html
                      --both for subsequent study and CG reconstruction. Also seems a good tool for preservation. Many sites have seen damage since their discovery and recording in their best state can help researchers in the future.
                        Roger
                        I believe 2D representation will eventually go the way of rock painting. We live and experience in a 3D world. You can't escape the fact that 2D is a lower bandwidth form of communication which implies our knowledge of the world around us is constricted by the use or 2D representation. Up til now we did not have the tools for 3D virtual representation. As our computer tools improve so will our repressed ability to fully exploit 3D virtual documentation.
                        In terms of a holistic understanding of our environment we are on the verge of great and valuable advances. Just think how much progress we have made in earth sciences since the introduction of satellite imaging. Three-D capture and presentation is the next step forward.Think what books were like before books with picture or images without motion or films without 3D. From here 3D documentation seems like a great leap forward, but as soon as we have it it will become the norm and no more remarkable that the telephone or the pencil.
                        http://www.azcreative.com
                        • B
                          bjornkn
                          Nice link 😄
                          Although it is always interesting to read about new hightech (and probably very expensive) tools for scanning the earth surface and below it is really a bit out of scope for this "survey", where I'm trying to find good uses for (and arguments for using) lowcost tools like SketchUp and tgi3D Photoscan. Most of what is found with Google appears to be very hightech/highcost.
                          Not that SU/Photoscan isn't hightech, but it isn't highcost in this context.
                          Looks like it is easier to find good arguments for using 3D for presenting archeological material to the general public than to find good arguments for using it as a tool for the professionals?
                          • GaieusG
                            As for some "non-destructive" (i.e. not digging) ways of archaeological reserach, here is a page a friend of mine put together on the occasion that they have an axhibition here: http://korarok.baranya.hu/index.php?lng=e
                            Very true and also somewhat sad. We have a 4th century chapel here on which we had a lot of arguments (how it may have looked like when not in ruins) and actually SU (and 3d) was the way to prove one of the theories. Yet it is still not taken for a way of "research" (or reasoning/proving) but just a "toy" to ply with after the "professionals" have finished their roles.
                              JGA
                              For software, AutoDesks 123D is worth a look
                              http://www.123dapp.com/catch
                              Regards,
                              JGA
                                Roger
                                I just downloaded this and gave it a try. Have you exported to a dwg mesh and tried to import to SU? I tried and SU said it could not open the dwg file.
                                  JGA
                                  Sorry, never installed it, but it could be a newer version of AutoCAD DWG that SKUP can handle.
                                  Regards,
                                  JGA
                                  • B
                                    bjornkn
                                    That was actually what I was afraid of - that it would be regarded as toys - maybe because it doesn't cost thousands or millions of dollars? I believe SketchUp has managed to get that "toy" tag (almost) removed after many years in the architectural business, although there's probably still a lot of skepticism from those who don't believe a program without an Autodesk logo (and a $10000+ tag) on it can be useful.
                                    Too bad those archeologists invovled in this current projects lives 1200kms away 😞
                                    This summer the local (county) archeological authorities will conduct a ground radar survey near a farm where a lot of my family comes from (back to the 1500s though..) There are some stone circles there (neolithic?), and they want to see if there is also something in the ground.
                                    Do you think they would just be annoyed if I offered them to do some photogrammetry 3D "survey" there at the same time?
                                    • GaieusG
                                      I don't know. Also, it is very much up to the person. I know architects here who still do not use computer for designing (although they employ draftsmen to do this). My archaeology professor has got to the point that he understands that digitizing data is important. So he now scans his site drawings. But when I try to explain him what the difference between raster and vector is, he is hopeless. But he regards himself as a modern person because he can send an email (true that he has not been able to update my contact details in his list for ages).
                                      So whet do we expect? Sooner or later, when decision makers in this industry are already from a next generation, things like this will slowly infiltrate.
                                        Roger
                                        Installed it and it is amazingly simple. I was even able to export as object file and import that into SU via TIG's OBJ to SU plugin. Also made an animation but I don't have the right codecs to get the animation working. I dont know as much about UVs as I should so proper texturing is a hang up. Biggest problem is lack of proper documentation.
                                          Roger
                                          On an archaeology related note. I was baby sitting for my daughter and her husband because they were going to see a Harvard Club presentation called "Mayan Apocalypse 2012: What to pack." It was a serious presentation but the presenter just couldn't resist the title.
                                          • B
                                            bjornkn
                                            It is strange that archeologists seems to jump directly from the "stone age" (tape measures etc) to the space age (very high-tech/cost lasers, ground radars, sonars etc) directly, without absorbing the "landscape" between? Architects went from paper/pen to 2D computer drafting and then 3D.
                                            However, I have now got the dates for that stone ring survey (with magnetometers apparently), and "permission" to come and "look" at them working. Guess I'll bring my cameras and fisheye for 360s, and then we'll see what happens. 😉
                                            11-13 april it is 😄
                                            • 1 / 3
