Component Drop on Terrain?
Hello,
I'm finding plugin which can put component or group onto the terrain.
Like put many trees onto the hill in the same time.I think I used to try this plugin but I can't remember the name of this plugin.
Please tell me if you know the name.Thank you.
Well, there's Didier Bur's Component Spray, and maybe Chris Fullmer's Components onto Faces? I think these are the authors, and I think these are their scripts. Correct me, if I am wrong.
There may be others in the Plugins Index. Also, check Didier Bur's Ruby Library Depot and maybe Smustard?These are just off the top of my head- what's left of it. You know, kinda tangled up in a few hairs here and there.
Thank you, mitcorb. I found what I seek now, it's smart drop (by a4chitect).
But it's still not correct to my need. My problem is show in the image below.All of these boxes are group and when I use smart drop, they will put perpendicular to the surface.
I just want it straight drop and touch surface only.
Then you can use my Raytracer plugin: http://forums.sketchucation.com/viewtopic.php?t=30509
Yes! Thomas! This is what I want
Your plugin save my time a lot. Thank you very much.
