    RICHARD'S ULTRA LOW POLY CARS - UPDATED
    57 Posts 42 Posters 86.7k Views 42 Watching
    • RichardR Offline
      Richard
      Thanks to all the sketchucationist who downloaded these files and left a vote of thanks. I've now moved them to the store to make them accessible to both members and non members.
      The low poly car set can now be found here > http://sketchucation.com/shop/models/319-ultra-low-poly-car-set
      Here is a PDF intro with features and tips on use.
      Ultra Low Poly Car Set.pdf
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
      • pbacotP Offline
        Thank you Richard. DL'd
        This is wonderful. The sort of service I'd expect to pay for at Formfonts etc... Do you take cookies?
        So you are the Richard of the Richard Technique!
        http://forums.sketchucation.com/viewtopic.php?f=79&t=43425&p=387576&hilit=richard+technique#p387576
        Thanks! I can really use this as I have recently been required to populate a parking lot (what a priviledge) and have few decent (and trim) cars in my arsenal.
        Peter
        • RichardR Offline
          Richard
          Thanks Peter glad the timing is good for you!! Be mindful though of my mention they aren't the prettiest and designed MORE for NPR...
          Really glad though someone may get use of them straight away.
          • RichardR Offline
            Richard
            Here is an model scale render where I have used them as cast metal versions. They do suit this style given the minimal detail.
            • pbacotP Offline
              Yes, I am doing NPR and it is a high view.
              In your picture, though I see the logic, I think it feels strange for them all to be one color, maybe white, black,silver, and bronze to fit the color scheme (mostly white cars).
                cheffey
                Thanks Richard. I have never seen a bad image from you. Inspiring.
                BROS RŌMAN BRΓ„UN
                • andybotA Offline
                  andybot
                  That's pretty cool Richard, thanks for sharing! Looks like with the detail lines it's great for NPR.
                    King Richard! 😎
                    • bazB Offline
                      baz
                      Thanks Richard, going to be very useful.
                      • utilerU Offline
                        utiler
                        I think some of these are numbers are familiar! what render package did you use here?
                        sweet.
                        Just Curious...
                          dtrarch
                          Richard
                          Really good of you to share with we the great unwashed.
                          Thank you a bunch. πŸ‘ πŸ‘
                          Nice work too.
                          dtr
                          • RichardR Offline
                            Richard
                            Thanks guys!!
                            Actually mate that's a brilliant idea!!! πŸ˜„
                            @Andrew
                            Mate beers sounds great!! Thanks for fixing the insertions on these I just never got around to doing it though still ended up redoing anyway to align to any plane otherwise you have to rotate them on sloping planes.
                            @ Bob
                            Wow mate that's cool, I played with a few as renders but gave up as they just weren't working to how I'd be happy with anything but just the plastics. Though you've shown they might work of in some engines.
                            I also guess that with the new artisan tools these could be easily improved. I made then by simply creating a box around an existing higher poly car, then sketched out the outline of needed features and dragged through in the 3 directions to crop the low poly model. After I added some sub divisions to form limited curves. Thats why the arse end on all is bit boxy.
                            It was all a bit of an exercise about 6-7 years ago to get as Low as possible.
                            • boofredlayB Offline
                              boofredlay
                              Thanks Richard.
                              • Bob JamesB Offline
                                Bob James
                                Took 15 minutes to throw on a set of brushed aluminum BMW wheels, some metallic blue paint and the old BMW X5 doesn't look bad at all πŸ˜„
                                Many thanks, Richard. It just so happens that I have a model in work that has a parking lot just waiting for your cars πŸ‘
                                Update
                                Just had to do a little with the headlights πŸ˜‰
                                  I think for most of you/us it goes without saying but I think it is not completely useless to mention that once you painted the certain elements (windows, wheels, lights etc.) as faces inside the groups/components, you can paint the individual instances of the same component with different colours - as long as they bear the default material - as it is also described with the examples of cars in the SU Help Manual, too.
                                  Great cars, Richard, thanks! πŸ‘
                                  • StinkieS Offline
                                    Stinkie
                                    Thank you, Richard. 😍
                                    • H Offline
                                      HFM
                                      Perfect combination between detail and low file size πŸ‘
                                        JGA
                                        Thanks for sharing
                                        Regards,
                                        JGA
                                          Ben Ritter
                                          Richard, thank you for sharing.
                                            tomsdesk
                                            Richard, you're a Prince! Now people can stop bugging me about the boxy cars in my renders...yeh!
                                            2.5D Trees & Shrubs!
                                            • 1 / 3
