    Error in visualization the correct scale of textures
    2 Posts 2 Posters 195 Views 2 Watching
      maskeight
      my problem is with the scale. I explained it. I draw my model in sketchup 8 pro in a wrong scale. For examples I had lenghts of 1000 meters instead of 10 meters. When I insert materials, obviously the texture was more more small. So I made smoller the model to the correct length. Now the problem persists because textures are however small. I tried to copy the scaled model in another new file and it is onether time the same story. How can I do? I know that I can scale textures on surfaces with the right click but in my case it should be a long process.
      Thank you!
        If you used components or groups, the texture will also scale down with them. If there are components, you can right click and "Scale definition". If they are groups, you will need to turn them into components first.
