    Need to place trees randomly
    8 Posts 5 Posters 998 Views 5 Watching
      mandar1983
      Hello,
      I m preparing a scene wherein i have to place number of trees and tht to randomly so tht it will giv the feel of a jungle. is there any plugin to place trees randomly on the surface..
      Also is there any way by which i can make the file light in size..cos when i star putting trees file gets heavy, i even tried crating ghost component of the tree but result was same....so need some help in tht also..
      Thanks & Regards,
      Mandar Karve
      • gillesG Offline
        gilles
        Have a look there.
        http://forums.sketchucation.com/viewtopic.php?t=33908#p298004
        • tridemT Offline
          tridem
          use components instead of groups as much as possible, then use the "compospray" plugin, or also "make fur" to populate πŸ˜‰
          • Alan FraserA Offline
            Alan Fraser
            If you are going to use a lot of trees then, yes, you will have problems with SketchUp. It doesn't like geometry as much as other 3D programs...mostly because it's always inferencing and native-rendering...even when you're not drawing anything.
            The way to get around this would be to use 2D Face-Me trees. You'll find a number of useful transparent png images here. You can import these, and turn them into Face-Me components.
            If you require visuals from a high vantage point, you might have to consider getting (or making) some 2.5D trees. These are usually Face-Me also...but instead of having a single vertical billboard image, they are made up of several smaller images layered at 45 or 60 degrees, so that they still look decent from a higher vantage point.
            Tom has posted some 2.5D trees on this thread, so you can see what I mean.
            3D Figures
              mandar1983
              Thnks Guys..
              Then Just let me know how to create face me trees if i want to..
              It would be gr8 help..
              Thnks,
              Mandar Karve
                Alan Fraser
                I'll put a tutorial file in the tutorial section.
                Link.
                3D Figures
                  mandar1983
                  Hi guys,
                  I was looking for a tutorial for creating face me component..if someone wanted to know tht as well then just watch video on youtube "The Sketchup Show #19: Face Me Component".. it will help if someone doesn't know how to create face me component... it helped me..
                  Now some one tel me how to make edges smooth in sketchup..any tool or plugin available for tht..i want to make cliff surface smooth
                  Thnks,
                  Mandar Karve
                    I also have one - I gues after a while everyone will cretae his/her own πŸ˜„
                    [flash=640,480:3e0grkv6]http://www.youtube.com/v/VvI6A7Njw4k[/flash:3e0grkv6]
                    As for softening edges...
                    1. select all and right click > soften/smooth edges. A dialog will pop up where you can pull the slider to the right until you are satisfied. This will soften every edge with the same degree.
                    2. softening selectively can be done with the Ctrl + tool
