    Push Pull direction?
    20 Posts 4 Posters 1.3k Views 4 Watching
      ksor
      I try to do this while ..end loop:
      <span class="syntaxdefault">            while </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$diaP </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MINDIAP</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$diaA </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MINDIAA</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$krv </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MINKRVD</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$krvB</span><span class="syntaxkeyword"><</span><span class="syntaxdefault">MINKRVB</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                    </span><span class="syntaxcomment"># Now display the input dialog<br /></span><span class="syntaxdefault">                results </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> inputbox prompts</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> values</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> $exStrings</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">GetString</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Specifikationer"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                    </span><span class="syntaxcomment"># Returner if no inputs<br /></span><span class="syntaxdefault">                return if not results <br />                if </span><span class="syntaxkeyword">((</span><span class="syntaxdefault">$diaP </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MINDIAP</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$diaA </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MINDIAA</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$krv </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MINKRVD</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$krvB</span><span class="syntaxkeyword"><</span><span class="syntaxdefault">MINKRVB</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">                    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Mindsteværdier skal overholdes !"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> MB_OK</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                else<br />                    $diaP</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> $diaA</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> $krvD</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> $krvB </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> results<br />                end <br />            end</span>
      and I get this error message:
      Error: #<NoMethodError: undefined method `<' for nil:NilClass>
      If I comment out my conditional testing in WHILE and IF then my code runs well !
      WHAT IS WRONG HERE ?
      Best regards
      KSor, Denmark
      Skype: keldsor
      • dereiD Offline
        derei
        Because you are trying to make comparisons between constants and variables that are not defined... first assign values to your constants/variables, then run the comparisons. Maybe some of them are defined in a part of code that you haven't shown to us, but it's certain that ruby tries to run " < " method against something that has no value, or you assigned NIL value (beware, NIL is not equal to 0(zero) !!, NIL means nothing!, zero is "something").
        DESIGNER AND ARTIST DEREI.UK
          You are making this look very complicated.
          Can you explain in simple words [not code] what you want to achieve?
          Where have you defined MINDAP=10.mm etc and all of your other constants ?
          Do this in the body of the class before any methods are called, or even inside the def initialize()...
          Where have you defined the prompts [DiaP: "", etc]
          where have you defined the default values [@diaP, etc]
          Also don't use $diaP etc
          use @diaP etc instead, AND give them a default value, e.g.
          @diaP=MINDAP if not @diaP inside the def initialize() of the class so if it's the first run it uses MINDAP or if later the current value of @diaP
          This is the simple form...
          results = inputbox(prompts, values, "Specifikationer") return if not results diaP, diaA, krvD, krvB = results
          THEN test for compliance of diaP etc and redo the dialog...
          Finally exiting with @diaP, @diaA, @krvD, @krvB = results
            ksor
            OK - some restructering but here is a code that WILL run correctly as it is now (WITH the out-commented lines 49, 56 and 68 !)
            IF you "activates" the WHILE loop again (remove =begin, =end and the end to the WHILE in the lines 49, 56 and 68)
            it reports an error missing an "end" in the end ??????????????????????=)(?/??=)(#?=)(?=#(¤/(#)=#&¤&
            The meaning of the WHILE loop is to secure that some MINIMUM input values are obtained.
            HOW CAN ACTIVATING THE WHILE LOOP CAUSE THIS ERROR missing an "end" in the end when it was no problem before - what is wrong here ?
            (For now never mind the modul and class lines)
            Here is the code:
            #module KSOR
             #   class polley
                    # store bogstaver evt. med _ er en CONST
                    MINDIAP = 40.mm
                    MINDIAA = 10.mm
                    MINKRVD = 20.mm
                    MINKRVB = 15.mm
            			# First check for PC or MAC
            		platform = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
            		if platform.to_s=="windows" then
            				# pull in the standard API hooks.
            			require 'sketchup.rb'
            			  # Get handles to our model and the Entities collection it contains.
            			model = Sketchup.active_model
            			$entities = model.entities
            				# Show the Ruby Console at startup so we can
            				# see any programming errors we may make.
            			Sketchup.send_action "showRubyPanel;"
            				# Add a menu item to launch our plugin.
            			UI.menu("PlugIns").add_item("Kileremskive") {
            					# Call our new method.
            				draw_pulley
            		else
            			UI.messagebox("Denne facilitet er KUN til Windows !", MB_OK)
            	# end main program -----------------------------------------------------------------------------
                    def draw_pulley
                        # labels for input fields
                        prompts = [$exStrings.GetString("Skivediameter (mm) ;"),
                                   $exStrings.GetString("Akseldiameter (mm) ;"),
                                   $exStrings.GetString("Kravediameter (mm) ;"),
                                   $exStrings.GetString("Kravebredde   (mm) ;")]
                        # default MINIMUM values
                        $diaP = MINDIAP
                        $diaA = MINDIAA
                        $krvD = MINKRVD
                        $krvB = MINKRVB
            =begin
                        while ($diaP < MINDIAP) || ($diaA < MINDIAA) || ($krvD < MINKRVD) || ($krvB < MINKRVB)
                            # test for minimum values in ALL - change the one less than minimum
                            if ($diaP < MINDIAP) then $diaP = MINDIAP
                            if ($diaA < MINDIAA) then $diaA = MINDIAA
                            if ($krvD < MINKRVD) then $krvD = MINKRVD
                            if ($krvB < MINKRVB) then $krvB = MINKRVB
            =end
                            values = [$diaP, $diaA, $krvD, $krvB]
                            results = inputbox prompts, values, $exStrings.GetString("Specifikationer")
                            $diaP, $diaA, $krvD, $krvB = results
                            if ($diaP < MINDIAP) || ($diaA < MINDIAA) || ($krvD < MINKRVD) || ($krvB<MINKRVB) then
                                UI.messagebox("Mindsteværdi er genindsat - de(n) SKAL overholdes !", MB_OK)
            #            end
                        draw_beltProfile
                        set_beltProfileOnWheel
                        pull_pulley
                        pull_krave
            		def draw_beltProfile
            			pt1 = [0,4.22.mm,0]
            			pt2 = [13.8.mm,0,0]
            			pt3 = [13.8.mm,12.7.mm,0]
            			pt4 = [0,8.48.mm,0]
            				# Call methods on the Entities collection to draw stuff.
            			$fullProfile= $entities.add_face pt1, pt2, pt3, pt4
            			$beltProfile = $entities.add_group $fullProfile.all_connected
            		def set_beltProfileOnWheel
                            # Her laves en profil, som svarer til en kilerem
                            # Skive laves
            			$periferi = $entities.add_circle [0,0,0], [0,0,1],$diaP.to_f/2,48
            				# transformation af helpLine på $beltProfile til Origo
            			tr = Geom;;Transformation.translation [-11.55.mm,-0.69.mm,0]
            			$beltProfile.transform! tr
            				# og videre til cirkelperiferien
            			tr = Geom;;Transformation.translation [$diaP.to_f/2,0,0]
            				# rotate beltProfile 90°
            			tr = Geom;;Transformation.rotation [13.8.mm,0,0], [1,0,0], 90.degrees
            			$entities.transform_entities tr, $beltProfile
            				# gruppen exploderes for at lave FollowMe og findes så ikke mere
            			$beltProfile.explode
            			$fullProfile.followme $periferi
            		def pull_pulley
                        # Nu skal siderne på skiven laves 2 mm på hver side
                        opSidePeriferi = $entities.add_circle [0,0,12.mm], [0,0,1], $diaP.to_f/2 + 2.25.mm, 48
                        opSideFlade = $entities.add_face opSidePeriferi
                        opSideFlade.pushpull 2.mm
                        nedSidePeriferi = $entities.add_circle [0,0,-0.7.mm], [0,0,-1], $diaP.to_f/2 + 2.25.mm, 48
                        nedSideFlade = $entities.add_face nedSidePeriferi
                        nedSideFlade.pushpull 2.mm
                        cleanUp
            		def cleanUp
                        # En cylinderflade fjernes, så der åbnes ind til remprofilen
                    def pull_krave
                        # En krave til nippel skruer laves efter angivne dimensioner
                        # og der skal laves hul til akslen med den givne diameter
            	# end  #class
            #end    # module
            Best regards
            KSor, Denmark
            Skype: keldsor
              I have put your post's 'code' inside 'code' []braces[/] - it's impossible to read meaningfully otherwise.
              Please learn to use these...
              A few general comments...
              I know the class is not currently activated but it should be **P**olley
              The menu item should be something like
              UI.menu("PlugIns").add_item("Kileremskive"){KSOR::Polley.draw_pulley()}
              Put require 'sketchup.rb'
              before the module starts - it only gets used if sketchup.rb hasn't been loaded before - it is a failsafe, if you are using any methods that this system script might need to have loaded...
              Why do you need to check whether this is a PC or MAC tool ?
              Most scripts/tools run just fine on both platforms you only need to check when some code is platform specific...
              Please learn to use @ NOT $ variables.
              Also
              will work without and 'end' IF it's this way round
              $diaP = MINDIAP if $diaP < MINDIAP
              [although you do need to test if the variable is set with
              $diaP = MINDIAP if not @diaP or @diaP < MINDIAP
              also use @diaP NOT $diaP!]
              You don't normally use/need a 'then' in an 'if' test in Ruby, although it won't beak anything, BUT you do need the 'end' unless the result is place before the 'if' as I have shown...
              Also learn to enclose arguments inside () with no space between the opening ( and its method - 'loose' arguments may be deprecated in future Ruby updates and therefore the API docs are all pretty much out of date...
              You could probably do with less transformations/exploding etc if you placed objects where you wanted them initially. I'd recommend you put all of your new geometry inside a group [or component] as it means there are no unexpected clashes with existing geometry... I haven't changed much of this though...
              I've recast your code into a working example for you [attached] - see how I have adjusted parts and then feel free to ask us more questions...
              !!!.rb
                ksor
                OK - nice with your comments and alternative if's and I'll study that closely BUT
                What about my WHILE-problem ?
                Do you mean that IF I DO like you said then this problem will disappear or .. ?
                Best regards
                KSor, Denmark
                Skype: keldsor
                  Read my edited post and the attachment...
                  The end was because the 'if' aren't properly formed and the first one 'steals' the while's end.
                  BUT my example shows how to avoid this 'while' loop altogether !
                  There were a number of overlaid issues - it's best to see my alternative reworking on how some things are just avoided/omitted or alternative forms will work as you hope...
                    ksor
                    OH, sorry I didn't see there was an attachment - sorry !
                    Best regards
                    KSor, Denmark
                    Skype: keldsor
                      ksor
                      Yeah, but now you took it a little further than I can cope with !
                      AND
                      😆 you should have tried to input a lower value than the minimum allowed - if you do you get this error:
                      Error: #<NoMethodError: private method initialize' called for #<KSOR::Polley:0xa9cd790>> C:/Program Files/Google/Google SketchUp 8/Plugins/RemSkive.rb:43:in dialog'
                      C:/Program Files/Google/Google SketchUp 8/Plugins/RemSkive.rb:25:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/RemSkive.rb:5:in new'
                      and NO re-asking of new input but that's surely caused by the error.
                      Best regards
                      KSor, Denmark
                      Skype: keldsor
                        OK simple typo - simple fix.
                        THIS version recalls the dialog on an invalid entry...
                        See how I split a 'draw_pulley' method off from the un-callable 'initialize' that I had inadvertently typed....
                        You should recognize much of your code/steps in the reworked version - I've just avoided the pitfalls of your while-loop, un-ended if's etc etc...
                        !!!.rb
                        • Dan RathbunD Offline
                          Dan Rathbun
                          $exStrings.GetString("Specifikationer") will NOT work. All LanguageHandler keys are English. The values that are returned, are in the other language.
                          You can open the strings files Notepad++ to see what the English key are.
                          Or at the console:
                          $exStrings.GetStrings.each_pair{|k,v| puts( %[key: "#{k}" = "#{v}"] )}
                          You can only access $exStrings if the Examples extension is enabled by the user. You should not rely upon it.
                          I'm not here much anymore.
                            Or at the console:
                            I've removed these from my test code as he doesn't need them, neither does he need to test for 'platform' either...
                            I think that he's trying to apply methods and ideas from several sources and thereby making a script that's much more convoluted that it needs to be...
                            At the moment it's actually a simple script to ask for some dimensions and create a 3d pulley wheel from them...
                              ksor
                              I'll study the code and compare it with my thinking of Class, Objects, properties ect.
                              But I beleave this is "the right! structure or ... ?
                              The next Object - let's a a drivebelt - should use this code as "template" (the structure) or ...?
                              Best regards
                              KSor, Denmark
                              Skype: keldsor
                                I think you are being over analytical.
                                There are many things you can do with Ruby, but in your case checking 'platform', 'translating' strings and so on... are far more than you need to do yo complete what you are trying for.
                                Meanwhile there are a few things that you are not doing, which we'll skim over for now as 'sufficient is fit'... it works without them and they are 'nice-to-haves'...
                                  ksor
                                  Ha, ha, too analytical - you can't be when working with OOP, I beleave.
                                  😄 I'm just trying to get a nice structure from begining of my Ruby eara.
                                  Dan
                                  ???? I don't know what you mean:
                                  "$exStrings.GetString("Specifikationer") will NOT work. All LanguageHandler keys are English. The values that are returned, are in the other language."
                                  It DID work fine, eventhough I can see TIG changed it - in fact it did work.
                                  My test for Mac or PC was code I found and I thought that code for Mac WAS special so why not make a test - but OK it's obsolete.
                                  Now I'll try to finish the pulley thing !
                                  Best regards
                                  KSor, Denmark
                                  Skype: keldsor
                                    The 'getStings' coded parts won't 'work' because it won't find your Danish word to translate in the standard '.stings' file, which is in English !
                                    Adding that code does no real harm, other than slowing things down slightly, because every time it checks for a translation it doesn't find it and uses the original string anyway...
                                    The principal of a 'language translator' tool is that the strings in the script-file also exist in a 'look-up' file - typically a '.strings' file [or for purpose made translators like my deBabelizer.rb it a .lingvo files]; the English word is matched against the foreign word FR Cat<==>Chat or ES Cat<==>Gato etc. I don't think Danish is a Sketchup 'locale' though. However if you are using an EN-US locale with a script using my deBabelizer lingvos appropriately then taking the standard ...EN-US.lingvo and swapping the Cat<==>Cat for Cat<==>Kat etc etc would display menus,prompts,dialogs etc in Danish strings rather than English...
                                    I suspect this is something not high on your agenda...
                                    The issue of testing for PC/MAC only arises when you do something that is platform specific - most simple API code is cross-platform; however, you might one day move on to Tools which for example involve key-presses, and these key-codes can vary between PC and MAC so you need to use different code depending on the platform test results; there are also add-ons like Win32ole.so and Win32api.so that add links from Ruby into the Windows system and even other app's like Excel - these cannot be used on a MAC so again you need to trap for that possibility... BUT your relatively simple code needs no sure 'traps'...
                                      Dan Rathbun
                                      @ksor said:
                                      Dan
                                      What TIG said is true.
                                      You don't need to worry about translating plugins just yet.
                                      $exStrings.GetString("khbgjubgeg663buib")
                                      returns >> "khbgjubgeg663buib"
                                      ... because the key "khbgjubgeg663buib" does not exist in the hash, and the LanguageHandler just echos the key (assuming it would be a valid English string.)
                                      It is a fallback feature. (I suppose Google should have output a "Key not found" warning to the console.)
                                        ksor
                                        OK - I see it's for internationalization of the code - I misunderstood this in the first place.
                                        Best regards
                                        KSor, Denmark
                                        Skype: keldsor
                                          ksor
                                          Now I'm a little over analytical again 😄 - I think your code here contains a bomb:
                                          			def draw_pulley()
                                                          @diaP = MINDIAP if not @diaP or (@diaP < MINDIAP)
                                                          @diaA = MINDIAA if not @diaA or (@diaA < MINDIAA)
                                                          @krvD = MINKRVD if not @krvD or (@krvD < MINKRVD)
                                                          @krvB = MINKRVB if not @krvB or (@krvB < MINKRVB)
                                          				return nil unless self.dialog()
                                          				self.draw_beltProfile()
                                                          self.set_beltProfileOnWheel()
                                                          self.pull_pulley()
                                                          self.pull_krave()
                                          		    def dialog()
                                          					prompts = ["Skivediameter (mm) ;",
        "Akseldiameter (mm) ;",
        "Kravediameter (mm) ;",
        "Kravebredde   (mm) ;"]
                                                              values = [@diaP, @diaA, @krvD, @krvB]
                                                              return nil if not results
                                          					if (diaP < MINDIAP) || (diaA < MINDIAA) || (krvD < MINKRVD) || (krvB<MINKRVB)
                                          						self.draw_pulley()
                                          						return nil
                                          					else
                                          						return true
                                          The call to self.draw_pulley is a sort of recursive - just returning nil would be better and then this in the initializing method:
                                          				until self.draw_pulley() != nil
                                          Right ?
                                          Best regards
                                          KSor, Denmark
                                          Skype: keldsor
                                            Sorry, I don't quite understand your point... 😕
                                            The tool initializes, it runs self.draw_pulley(), which runs self.dialog() and tests for the validity of its ' return'.
                                            If the user cancels the dialog ' nil' is returned and it stops.
                                            If the user enters valid inputs it returns ' true' and the remaining steps are executed to completion.
                                            If the user enters invalid input it then re-runs self.draw_pulley() [], which in turn runs self.dialog() and tests for its validity in its ' return' etc etc in a loop until either the user cancels or enters valid input...
                                            after it re-calls the method it immediately returns ' nil' to the previously executing version of the method, so that one goes no further]
                                            Note how two sets of references are taken from the ' results', one to test their validity and if OK then another @ set to be used in the next methods and also remembered for the next time...
                                            I left it this way because that's what you originally showed... personally I feel that a simple
                                            UI.messagebox("Values outside limits !\nExiting.") return nil
                                            would do, but at least this way the user does get chances to try again with a valid input in a new dialog - if they want to give up they can just cancel the dialog at any time...
