    Ruby transformation issue?
    4 Posts 2 Posters 283 Views 2 Watching
    • T
      tomot
      I'm trying to graphically explain the following coding problem I'm having, please see the attachment.
      Under 5, I would like to use a move transformation of that face, only, to a new location, without it affecting the entire transformation which follows in 6. How would I code that move transformation to affect 5 only?
      my plugins
      tomot
        I don't think that .move! is really what you are after...
        to rotate the group itself try...
        group.transform!(t)
        OR if you want to change the contents WITHIN the group use...
        group.entities.transform_entities(t, group.entities.to_a)
        If you want to JUST affect the 'base' inside the group use...
        group.entities.transform_entities(t, base)
        BUT 't' can be any 'transformation' you want...
        • T
          tomot
          the rotation works as written, It just happens the 4 new points defining the new face in 5 need to be moved/centered before 6 rotates all of these entities (think about moving a glass plane to the center of a window frame before the entire window frame and glass gets rotated)
          The alternative naturally would be to simply create 4 new points defining a face at the center of the window frame. in which case I would not be asking for help.
          my plugins
          tomot
            So as I thought I had explained... make a transformation [tb] for 'base' and use it just on that entity
            group.entities.transform_entities(tb, **base**)
            THEN make and use another transformation [t] on the whole 'group'...
            Also note that your approximations of PI etc could be replaced by 60.degrees or other values in degrees, to give consistently accurate angles...
