    [Code] PCFileTools
    27 Posts 3 Posters 4.4k Views 3 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      The main point, I'm trying to get across.. is future implementation.
      Ie, how scripters will wish to use unicode extensions to File, Dir and String.
      The goal is to write cross-platform plugins.
      Ex:
      MAC =( RUBY_PLATFORM =~ /(darwin)/ ? true ; false ) unless defined?(MAC)
      WIN =( not MAC ) unless defined?(WIN)
      module Author
        class FancyTool
          if WIN
            require('skx/win/File')
            File = SKX;;WIN;;File
          # Now he can use File as he's always done.
          # On Mac, there is no local constant "File", and the
          # call is evaluated to the object, that is referenced,
          # by the toplevel constant "File".
          # But on PC, within this namespace ONLY, the call
          # is evaluated, to the object pointed to, by the
          # local (constant) reference "File", or fully
          # qualified; "Author;;FancyTool;;File",
          # which does not touch ;;File (aka; Object;;File)
        end#class
      end#module
      There is no way, scripters will want to changed all calls to methods of class File or Dir, into platform conditional statements, like:
      filename =( WIN ? PCFile.basename(pathstr) ; File.basename(pathstr) )
      or (worse):
      filename = if WIN
      else
      πŸ€“
      I'm not here much anymore.
        Dan Rathbun
        @tig said:
        A lot of this is 'above my pay grade'...
        No doubt that goes for any single ONE rubyist. Something like this needs to be a group project.
        Others have done some work in this area already. ThomThom on wide strings (which also need to be addressed, because many of the base class String methods, will garble unicode strings.)
        Dan Berger's "win32-api" toolkit plays a bit with creating a WideString class. (I think he considers it beta.)
        Also, we should not ignore the extended class Pathname (which is actually a wrapper class, not a String subclass.)
        @tig said:
        We can then debate later how the finalized 'fixed' methods are shoehorned into Ruby... πŸ˜‰
        OK, I made my point, on this issue.
        The only thing to add is to state the obvious. There are really only 2 alternatives.
        My suggestion is the least invasive, with the least responsibility. (Authors are left to decide to use the extension on a namespace by namespace basis.)
        The other option, to actually redefine any Ruby base classes that will use unicode strings, on the Windows platform(s).
        This would mean taking responsibility for string functionality of ALL plugins (running on Windows.)
        Not what (I think,) you would wish to do. Nor any project group. (Not at least without compensation, of some kind,.... and a lot of time to devote to the "cause.")
        Even the Ruby Core guys are taking forever to implement unicode support.
        Enough said... πŸ˜’
          Dan Rathbun
          @tig said:
          ... although I'd be wary of overwriting base class ?
          I didn't say anyone should. I said they should be subclasses of the base class. If they are, Ruby would not let anyone make the subclass overwrite the baseclass, because it would be a circular reference.
          EDIT: I tested this at the console. Ruby does not check for circular references using the c-side **=** operator. Anyway, it does not actually create a circular reference. The reference to original baseclass becomes un-identified by any constant, but the object can still be got, via the superclass() method.
          Making a LOCAL constant point at an object (in this case a Class definition,) does not overwrite anything.
          Now obviously, if some stupid 'newb' types File = SKX::WIN::File in the Ruby Console, or in an unwrapped script, THAT global constant that references the base class definition object, is changed (and affects all scripts that are also using it.) So, in order to set it back [without restarting,] it might be a good idea to have a 'secret' reference to the base class definition, kept "out of sight."
          module Ruby
            Refs = {}
            # base classes
            Object.constants.sort.each {|ref|
              obj = Object.class_eval "#{ref}"
              Refs[ref]= obj if obj.class==(Class)
            # base modules
            [Comparable,Enumerable,Errno,FileTest,GC,
             Kernel,Marshal,Math,ObjectSpace,Process].each {|obj|
              Refs[obj.name]= obj
            Refs['TOPLEVEL_BINDING']= TOPLEVEL_BINDING
            Refs.freeze
            def self.reset_object_ref(ref)
              if ref.is_a?(String) || ref.is_a?(Symbol)
                ref = ref.to_s
              elsif ref.is_a?(Module) # includes Class
                ref = ref.name
              else
                return nil
              if Ref.has_key?(ref)
                begin
                  eval( "#{ref} = ObjectSpace._id2ref(#{Ref[ref].object_id})", TOPLEVEL_BINDING )
                rescue
                  return false
                else
                  return true
              return false
          end#module
          EDIT: I added a reset method to the example, just for kicks.
          @tig said:
          I've kept everything separated for testing - so it still works provided you substitute PCFile.exist?(filepath) for File.exist?(filepath) and so on...
          You won't find many who are willing to go through their code and search and replace, "File." with "PCFile.", besides you haven't provided aliases for the methods you did not implement, which makes a simple editor search and replace, into a tedious manual edit session.
          You might consider, overriding the method_missing callback, whilst you still have them as custom modules:
          def method_missing( sym, *args )
            if File.respond_to?(sym)
              File.method(sym).call(*args)
            else
              raise(NoMethodError,"undefined method `#{sym.to_s}' for #{self.name};#{self.class.name}",caller)
          end#def
          and similar for PCDir:
            if Dir.respond_to?(sym)
              Dir.method(sym).call(*args)
            else
          end#def
            Dan Rathbun
            @tig said:
            ... and I can't see currently how to do the equivalent of ' binmode' etc. Any suggestions/additions gratefully received..
            Ya know.. it's weird that the Core guys made this switch, without a way to test later IF the stream was IN binmode or not.
            I checked the docs, and the Ruby 1.8.7 branch is still the same.
            BUT... in the 1.9.x trunk, they have added a binmode?() boolean query method. (See the online docs for IO class. They also added methods binread and binwrite, special open methods.)
            Of course, they have added a bunch of options, to read and write in several encodings.
              Dan Rathbun
              What effect do you imagine WIN32OLE.codepage= WIN32OLE::CP_UTF8 would have over CP_ACP (ANSI?/ASCII?), which seems to be the default.
                Dan Rathbun
                Ok TIG.. a general question:
                most all of the methods are doing this:
                arg = arg.unpack("U*").map{|c|c.chr}.join
                which seems to convert a UTF-8 string (if it is one,) to an ANSI string, before passing it to Windows FSO methods that take and return Unicode strings ...
                1) correct ??
                2) and why ??
                  I found that if I didn't do that change to the string then any tests of UTF-8 strings, like PCFile.exist?(path) do not work properly and return ' false' when it should be ' true'... just like the File.exist?(path) version; BUT making that change to the string before testing it seems to return correct results - consistently ' true' when it should be ' true' and ' false' when it should be ' false'. For a simple ANSI character string it works fine either way [the unpack/join has no affect], but if you test with a UTF-8 string with accented characters [perhaps obtained from a UI.openpanel()], that is unpack/joined etc then you can see the difference between what the File.. and PCFile.. versions return...
                  There's probably a more elegant way to do this... BUT it seems to work the way I've bodged it together, so now perhaps we can think of better ways of achieving the same difference... πŸ˜•
                    Dan Rathbun
                    That seems to indicate that the FSO methods are doing ANSI comparisons (perhaps by default.)
                      So, does PCFile.exist?() return true for a file with, for example, Japanese characters?
                        Dan Rathbun
                        Would the Japanese Kanji chars be in the UTF-16 set?
                        Ya know we are all back to the ol' String encoding problem, really.
                        I thot about using Dan Berger's String subclass(es) WideString or whatever he called them, but it seem like it would be combersome. Unless they converted themselves automatically similar to how Numerics use coerce().
                        Currently the interpreter always makes ANSI strings from **" "** and **' '** literals. (and their **%**dilimeter equivs.)
                        I wonder if possible to create a %u function that creates UTF8 strings. And maybe a %U that creates UTF16 ?
                        (Are these defined in Kernel, or are they C-side interpreter functions?
                        (Just throwing issues in the air, "musing out load.")
                          The underlying problem in Ruby 1.8 under windows is that it calls the A version of the file functions instead of the W versions. If a function is called FileFunction is used in C/C++ - when compiled it will translate to FileFunctionA or FileFunctionW depending on whether UNICODE is defined.
                          I was thinking that a C Extension that would forcefully call the FileFunctionW variants would be sure to work as it would be the system doing all the work. Meddling with the string in Ruby is quite likely to cause data to be lost or corrupted.
                            I only works for UTF-8 [i.e. 'European' accented-characters etc] - the more complex Chinese/Japanese return false when it should be true πŸ˜’
                            However, if we have a way of resolving one hopefully the other will follow...
                              http://www.danielstutzman.com/2011/04/how-to-write-unicode-filenames-in-ruby-1-8-6 uses Win32API and iconv ...
                                Dan Rathbun
                                BTW.. if interested:
                                This is the Extended lib module FileUtils from Ruby v1.8.6-p287
                                module FileUtils (Ruby v1.8.6-p287)
                                  Dan Rathbun
                                  from the old Pick-axe Book:
                                  Strings are stored as sequences of 8-bit bytes,[For use in Japan, the jcode library supports a set of operations of strings written with EUC, SJIS, or UTF-8 encoding. The underlying string, however, is still accessed as a series of bytes.] and each byte may contain any of the 256 8-bit values, including null and newline. The substitution mechanisms in Table 18.2* on page 203 allow nonprinting characters to be inserted conveniently and portably.
                                  • refers to the table of ** codes
                                  Also Standard Types: Strings
                                  So it seems that (in my mind,) since Sketchup sets $KCODE to UTF8 when it loads the interpreter, we may not actually have as much of a problem on the Rubyside as I thought.
                                  So we have a choice...
                                  1) A pure-Ruby patch, that either accesses the system calls (for File functions,) via WIN32OLE or WIN32API (the so libraries.)
                                  2) A compiled C patch, ie: "Cut out" the c code files that define classes IO, Dir and File (perhaps also FileTest,) and recompile with either UNICODE #defined, or change the C function calls explicitly to the wide versions. These would be ".so" files, and they would redefine the old methods. (What happens on the C-side when you re-define a C function that has already been defined? Do the C functions that the new Ruby wrappers call, need to be renamed as well?)
                                    I was thinking that a C extension that did most of the functions used, like File.exist?, read, write, delete and list files in folders would go a long way. It wouldn't be as extensive as a complete rewrite - therefor more quicker to develop. Then off course not replacing the existing methods - as it'd just open up a vast pool of possible problems which would require even more testing and development.
                                    Trying to rewrite the entire File, Dir and IO classes to call the W variant file function just seems like such a massive undertaking that it'd probably never be completed.
                                      Does Sketchup set $KCODE to "UTF8" in all locales - I know it does in UK/US and probably European language locales BUT what about Chinese ? I'll ask someone...
                                      If we get a consistent code for their locale can we modify the pack/join code to say use 'u' not 'U' and get an appropriate conversion in different $KCODE cases ?
                                        Dan Rathbun
                                        @thomthom said:
                                        Then of course not replacing the existing methods - as it'd just open up a vast pool of possible problems which would require even more testing and development.
                                        Well what I said before still goes... The new class(es) are in a Library namespace, need to be require(d), and then referenced within an author's namespace via an alias, (as I showed in the examples above.)
                                        I mispoke when I said redefine, they would have the same identifiers, but be within, say SKX::WIN module namespace.
                                        I was hoping (without yet digging into the C source,) that it might be easy to use Notepad++ search and replace to stick "W" where they need to be.
                                          Don't think it's that easy. I think there's a few type definitions that also needs to be adjusted. And then you need to ensure that there's no hard coded struct or data type sizes used...
                                            Dan Rathbun
                                            Poking around, finding links to help Adam on his Hebrew webdialog problem, I ran across a link on the Wikipedia Windows Code Pages doc.
                                            Down at the bottom:
                                            See also
                                            AppLocale β€” a utility to run non-Unicode (code page-based) applications in a locale of the user's choice.
