    Straw bale construction.
    18 Posts 4 Posters 960 Views 4 Watching
      Starling75
      [flash=600,400:1encaogi]http://www.youtube.com/v/XgbORHvveTY?version=3&amp[/flash:1encaogi]
      http://www.starlingarch.cz
        Roger
        One of her consultants owns the Canelo Project where we stayed last weekend. I think I even recognize the mountain in the background.
        http://www.azcreative.com
        • daleD Offline
          dale
          There is one other consideration with straw bale, or for that matter, cob or light clay infill, and that is structure. The company I work with a few of these projects, but quite often they are hybrids, with a combination of timber frame, or funky log post and beam. We are lucky to work with an engineering prof from the University of Manitoba who specializes in green construction systems.
          They are a lot of work, but the freedom to play with organic shapes can be quite fun.
          These are a couple of shots of a project called St. Anne's Garden Club which is a theraputic gardening centre for seniors. The straw bale is the mass wall between the greenhouse and studio.Screen shot 2012-01-18 at 6.44.50 PM.png
            Starling75
            403 Forbidden
            (www.ateliersea.com)
            http://i.lidovky.cz/11/072/lngal/TER3c63f7_RA5slamdum02.jpg
              Roger
              Had to study the photo for a bit to understand what is going on. Does the straw stay non plastered? There is a brick wall within the straw? The straw is "sacrificial." How many years will the straw last before needing replacement? Rain in the "impact crater" always falls straight down and the walls will stay dry?
              The shutters on the second floor slide laterally?
              How about solar mass? Straw insulates but will it absorb enough heat to radiate it inward during the night.
              If the glass is on the south won't it over heat the building during the day, but supply no gentle transmission of stored heat during the night?
              Interesting building but I need some help understanding the fine points.
                Roger
                Dale, when you say straw bale requires a lot of work, are you referring to design or construction or both? Are engineering calcs a big deal on a one story? How much will a compressed straw bale settle over time? Wouldn't it be better to have the roof settle with the house rather than having air gaps start to form under the beams? Should straw for structure or just act as infill?
                • jarynzlesaJ Offline
                  jarynzlesa
                  hi roger,
                  i have attached file that might help.
                  bohdan and dale ๐Ÿ‘ .
                  navodnastavbudomuzeslamy.pdf
                  http://www.vizualizaceschodiste.mypage.cz/
                    Starling75
                    Try this article ... (google "translated")
                    This video shows some details but the commentary is in czech language.
                    http://www.ceskatelevize.cz/ivysilani/10123096165-artmix/208562229000011/obsah/144713-artfor-dum-v-kozichu-a-s-destnikem/
                    • daleD Offline
                      dale
                      Roger
                      I think the design and engineering are pretty straight forward, or at least at par with most construction projects. Where I work, it would be impossible to build a straw bale, or any "out of the box" style building without an engineers stamp, and I only know of one straw bale building that has the roof sitting directly on the bales, and that was considered an agricultural building, which has a different set of code standards applied to it.
                      Construction is a lot of work, and the detailing requires specializes attention (ie door and widow jamb thickness and treatment, prep for cabinetry), but in most cases the labour is supplied by the owner, so, if your committed, it really becomes a labour of love.
                      The mass of straw can vary substantially but still comes in at about 7-14 lbs per cubic foot, however, it is not the actual capacity of the single bale, but how the bales react in the whole wall envelope. For this it is advisable to go with the lowest figure and the R- value then comes out to about R-1.3/inch. Attached is a pretty good primer put out in California, which is filled with specific info on straw bale walls.Straw bale info.pdf
                      I think jaryn's illustration pretty much sums up the kind of hybrid design engineers here find acceptable from the get go.
                        Roger
                        Jaryn and Dale, really interesting reading. Once again Bill Steen of the Canelo project are mentioned in the documents. It was interesting to have stayed overnight where I could see more of this first hand. At the moment I am very busy, but promise that you will hear more from me on the subject in the near future.
