    Smooth moving by pressing alt or smth?
    3 Posts 2 Posters 1.7k Views 2 Watching
    • john2J
      john2
      often while moving heavy objects, the movement becomes jerky instead of smooth one. just like in photoshop and some other software, holding a ctrl or alt button smoothens the movement. is there anything like that in sketchup? The most precise movement i do by putting guide points and then moving.
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • Jean LemireJ
        Jean Lemire
        Hi John, hi folks.
        In SketchUp (SU), normally you move an object to put in a precise location and thus will need either to specify this location by entering values in the Measurement Box to perform a relative move or an absolute move or you will snap the object to some other geometry. These can be anything like an edge, an endpoint, a midpoint a center point, a guide, a guide point, a face, whatever.
        The apparent jerkyness of a movement is irrelevant as long as the object being moved end up at the intended position. However, this jerkiness can be minimized if SU has less geometry to show. In other words, try to minimize the workload on the GPU (Graphic Processor) by using less demanding rendering mode like shadedinstead of shaded with textures, no shadows, no fancy edge styles, etc.
        You can memorize rendering setups with scenes. For example, using Styles, create a minimalist rendering mode for work that you will use when modeling including moving and then create another mode that have all the bells and wistles. Create two scenes, each one using one of these styles. Disable, however, the camera position memorisation for these scenes to avoid loosing a crefully orbitted, panned and zoomed view.
        Once that is done, you simply click on the minimalist scene tab to work. Your model will the respond fluidly. when ready to see it in its full glory, click on the other scene tab.
        Note that with a relatively simple model, you shall not experience such jerkyness unless your graphic card is not very strong or you have disabled fast feedback or hardware acceleration or both in the Open GL preferences.
        Just ideas.
        • john2J
          john2
          Thank you sire for the reply . i'm using the thinline mode with no colour..[purple and white faces mode] i have disabled only hardware acceleration because when i make a selection window, the monitor goes black with lots of coloured rectangle pieces scattered over it. i still have to find a graphic card driver update. i have a gigabyte brand motherboard, they still haven't released new updates 😞
