    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [SOLVED] Booleans operations available to free SU?
    9 Posts 4 Posters 693 Views 4 Watching
    • jolranJ Offline
      jolran
      Hi!
      Is for ex: group1.subtract(group2),available to free version users of Sketchup?
      It says version 8+ in the API, but I got unsecure it will work for everyone when I was adding it to my code.
      Intersect_with is faster, but it's not trivial to heal the intersections afterwards..
      Thanks.
        driven
        hi jolan,
        if you write a test, I'm sure someone will run it... no need to be a 'coder' themselves... john
        • jolranJ Offline
          jolran
          Hi John. Thanks for replying.
          Thought I would get a quick yes or no on this one.
          I'm using the solid subtract method for some tests in "Hatchfaces" development.
          So it's kinda burried in the code.. Kinda difficult to post a test snippet for that purpose from my code just yet.
          Maybe later when or if it's a more definitive solution.
          • Dan RathbunD Offline
            Dan Rathbun
            I checked the Release Notes webpages for both the app and the API, and it's not clear.
            I'm not here much anymore.
              driven
              I was thinking a copy/paste 'visual' test like this may be useful
              subtract
              # Test booleans on Free
               #Create the box
              ent = Sketchup.active_model.entities
              face = ent.add_face [0,0,0], [1,0,0], [1,1,0], [0,1,0]
              face.reverse!
              face.material = Sketchup;;Color.new("Coral")
              face.pushpull 1
              Sketchup.active_model.materials.add "Purple"
              group1 = ent.add_group face.all_connected
               #Create the 2nd box
              face = ent.add_face [0.5,0,0.5], [1.5,0,0.5], [1.5,1,0.5], [0.5,1,0.5]
              face.reverse!
              face.material = Sketchup;;Color.new("GreenYellow")
              face.pushpull 1
              Sketchup.active_model.materials.add "Blue"
              group2 = ent.add_group face.all_connected
               #test .subtract
              entities = Sketchup.active_model.entities
               instance1 = entities[0]
               instance2 = entities[1]
               result = instance1.subtract(instance2)
              =begin
               #test .union
               result = instance1.union(instance2)
                #test .trim
               result = instance1.trim(instance2)
               #test .split
               result = instance1.split(instance2)
               =end
              union, trim and split can be swapped to test them as well.
                driven
                in answer to your original question,
                I just installed free on this laptop and copy/pasted my code...
                Error: #<ArgumentError: (eval):25:insubtract': 'subtract' is a Pro only feature.>
                (eval):25
                (eval):25`
                  It's dead easy to post a test script and a snippet.
                  Make a SKP [v8] with two cubes that are separate groups that partially overlap.
                  Select the two groups.
                  Copy/Paste into the Ruby Console a short one-liner for v8-Free to test...
                  Something like:
                  s=Sketchup.active_model.selection;s[0].subtract(s[1])
                  Does one get subtracted from the other in v8-Free?
                  I suspect NOT.
                    Dan Rathbun
                    (eval):25
                    (eval):25`
                    Makes sense.. otherwise we'd be able to write Pro feature custom tools for Free. which defeats the purpose of a Pro version.
                    • jolranJ Offline
                      jolran
                      Was gonna post a snippet this morning but you guys did the work for me ๐Ÿ˜„
                      So I see John, you got an error "is a Pro only feature."
                      That pretty much sums it up. Like Tig also suspected.
                      Dan said.
                      Yeah, thats why I posted the question. Being a PRO user I momentarily took this method for granted when I did not receive an error message in my code.
                      Thanks everyone involved for clearing this up.
                      Maybe Google should put PRO label for methods like this after the 8+ in the API.
