    [request] plugin to use while distribute an program
    4 Posts 3 Posters 240 Views 3 Watching
      Jorgensen
      Does anyone know if there is a plugin for use inside sketchup while one is sketching ?
      We often start with a list of rooms and their sizes, a program. And it would be nice to use sketchup to distribute the rooms.
      What I would like is a plugin where you enter the program (import excel file?) and somehow relate the single room to an face (or other object?) and when you scale the face the area updates.
      The program and actual areas should be listed, on a scheme and on the object so one can se if the areas has the requestet size.
      Does anyone know if such plugin exists ?
      Thanks πŸ˜„
      • dukejazzD Offline
        dukejazz
        This info may help
        [Plugin] ComponentReporter++ v1.1
        by TIG on Thu Apr 09, 2009 6:10 pm
        Here's v1.1 of ComponentReporter++.rb.
        It does report names, count of instances, nested instances/groups and areas of materials etc...
        Try it - it is readily adaptable to your needs...
        http://forums.sketchucation.com/viewtopic.php?f=323&t=23991&p=373724&hilit=excel#p373724
        also
        Re: Excel to SU ( 29/7/08 version )
        by coulteri on Mon Jul 26, 2010 9:03 pm
        Hello,
        here are some examples:
        attachment No1 is small example of terrain data (only 25 boxes). No2 is table with coordinates of border points of these boxes. No3 is example of what I would like to reach.
        Thanks. C.
        http://forums.sketchucation.com/viewtopic.php?f=180&t=11572&p=362484&hilit=excel#p362484
        • jeff hammondJ Offline
          I saw this on the sketchup blog recently:
          Making your models more useful with Trelligence Affinity
          Follow the SketchUpdate blog for SketchUp news, modeling tips and tricks, user stories and more.
          (sketchupdate.blogspot.com)
          i'm not 100% sure it's what you're after because i can't try it out (i'm on mac.. this is windows only)..
          check it out though..
            Jorgensen
            hi jeff and dukejazz
            I stumbled on TIGs AreaTextTag, and it gets my on the road for now πŸ˜„
