    Copy in line of succesion
    1 Posts 1 Posters 305 Views 1 Watching
    • GaieusG
      It's called "Linear array" (See somewhere at the bottom here)
      Basically:
      1. select the group then the Move tool
      2. press Ctrl key (no need to hold down)
      3. move a copy where you want (snapping on top of the original for instance)
      4. type x7 (for instance) and hit Enter. Together with the first copy, 7 instances will be "arrayed".
        You can do "Radial arrays" with the Rotate tool in a similar way.
