    [concept] plugin launcher
    39 Posts 10 Posters 7.3k Views 10 Watching
      Jim
      When I inspect the html in the dialog, I see it is incorrectly nested somehow..
      <HTML><HEAD></HEAD>
      <BODY><PRE>&lt;!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/strict.dtd"&gt;
      &lt;!--
      This file is required by LaunchUp.rb"
      Copyright 2011, Andreas Eisenbarth
      All Rights Reserved
        Aerilius
        I'm not sure what is nested wrong? (I haven't found it yet)
        I know many browsers internally prepend a <HTML><HEAD></HEAD><BODY><PRE> when they display plain text files, so maybe this is only the result instead of the cause why IE shows the plain text.
        I found that the doctype makes no sense (transitional <-> strict). Can you try
        <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
          Jim
          I tried the new doctype - nope. I got rid of the doctype and comment beginning the .htm file with <html> and it started working again.
          I put the doctype back in and removed just the comment - it worked.
            driven
            I've got v2 stable enough to start looking at it on Safari... Selection from the search results only works with new keycodes and not the mouse...
            HTML Changes include:
            added a break after 'form' and moved the js to below that break... so line numbers reflect this.
            Line 01- DOCTYPE html
            Line 22- added to body>> height:100%;
            Line 23- changed in form>> top:4px;height:inherit;
            Line 49- input type="search"
            Line 57- [<]br /[>] ...without []
            Line 59>>296- scripts
            Line 210/211- // left-arrow: select first entry
            if (keycode == 37) {
            Line 222/223- // right-arrow: execute entry
            if (keycode == 39) {
            Line 275- // $("combo-input").focus(); #jb_mac
            in the Rudy:
            this forces it to only scroll down
            Line 54- changed to @launchdlg = UI::WebDialog.new("LaunchUp", false, false, 0, 1140, 270, 50, true)
            Line 92- added @launchdlg.set_position(1140,0)
            to get it to show_modal
            Line 98>>102 + Line 110>>102- if RUBY_PLATFORM.include?('darwin') # Do NOT 'do this if on a PC! @launchdlg.show_modal else @launchdlg.show end #mac _modal
            I also set a shortcut key in 'system' preferences and have started updating the txt file.
              Aerilius
              Thank you so much for your efforts! I included it in the code. For me it used to work in my browsers/configurations, so otherwise I couldn't have found these solutions on my own.
              I did some search about comments between doctype and <html>, but didn't find anything about issues. I probably leave the comment completely away (or does it work with the comment after <html> ?)
              I was a bit hesitant about %(#000000)[input type="search"] because it's not standard (html4), but since unknown type defaults always to text, it shouldn't be a problem and doesn't break anything in Internet Explorer.
              • Dan RathbunD Offline
                Dan Rathbun
                It IS a bit weird that the comment is outside the <html> block... I would put it inside the <head> block as well.
                I'm not here much anymore.
                  driven
                  Hi all,
                  I'm bumping this, because I want to modify it to work with 'on_off' http://forums.sketchucation.com/viewtopic.php?f=180&t=41994#p372262
                  Using the option to open SU without rubies but with Ruby we have the ability to open individual .rbfiles or folders containing .rb files using Alex's + Jim's methods or load from RC, which is great.
                  However if you want TIG's 2DTools [for example] you need to change all the 'requires' in all the scripts into 'load' + full the path before it will run with 'rubies' turned 'off'. I've got that working and it will still run as normal with them 'on', but would be a pain to do for each new version for all my rubies. I haven't worked out any of Fredo's yet, but I'm sure there's a way.
                  So I'm thinking it would be a lot easier to parse the plugins each time you call one to 'load' and leave the originals intact,
                  if it needs support files they can be added, but also need full path's.
                  Basically, use 'LaunchUp' to select the 'standard' ruby rather then it's individual items,
                  because you only need to have a few sets on at a time the toolbar count is still low.
                  when you get to many you start again.
                  I'm stumbling through so any feed back is appreciated.
                    Aerilius
                    This is very far from a proper plugin. Parsing other ruby files in order to get commands is not an ideal solution and needs always manual editing. I would not publish the current state as a plugin.
                    I've played around with alternatives (should probably make my current version ready and post it here). I tried aliasing the UI::Command before all plugins load. Problem is that this way I modify core methods, I have to make sure that my plugin loads always first and it can be harmful if another plugin aliases UI::Command.
                    Jim inspired me to get the commands with Objectspace, which works for all the command's metadata, but I haven't figured out how to call the proc.
                    Third possibility is to continue hoping and begging for SU9 that we will have better access to commands (and maybe removing/modifying toolbars and menus).
                      lapx
                      This idea deserves an award! I spend too much time trying to find certain commands and dealing with grey out issue.
                      Is it necessary to create another plugin folder or can I just check not load at start up.
                      Have'nt tried yet but appears to be a winning concept if it can work smoothly.
                        driven
                        Hi Aerilius,
                        thanks for replying
                        I may have found a workaround for what I'm after using Fred's '000_AdditionalPluginFolders.rb' with 'on off.rb',
                        I've made and registered some subfolders in SU, then when I launch with 'rubies OFF' and run '000_AdditionalPluginFolders.rb' I get asked which I want to instal, so I can choose 'Base Set', '2D', 'Fredo' or 'TIG', etc...
                        This avoids having to look at or modify the rubies content at all and with a simple folder creator/sorter WebDialog this is almost doing what I want [on mac at least] and without any .rbs [but they can be accessed via a full startup].
                        I'll keep digging
                          Jim
                          Once you have a reference to a proc, call call on it.
                          pr = Proc.new { puts "Hi" } pr.call Hi
                            Aerilius
                            But can I get the proc from Objectspace? I didn't get it to work...
                              Jim
                              Oh yeah. You can get UI::Command objects from ObjectSpace, but you can't get a handle to a Command's associated Proc.
                              You can get Proc objects from ObjectSpace
                              ObjectSpace.each_object(Proc) {|pr| puts pr }
                              But there is no handy way to know which command a Proc is associated with other than the String representation (which is the filename and line number where the command is created.)
                              So no "good" solution. I have asked Google for a method to access the Proc of a Command. That would make things sooo much simpler.
                              • dukejazzD Offline
                                dukejazz
                                Your idea of a launcher with a quick search, is something Im looking for. Type a search for any plugin/tool that you want to execute. If the plugin is not yet loaded, it will be loaded instantly.
                                "The basic purpose is to keep only a small range of standard plugins (=> quicker start of SketchUp and uncluttered interface), but make it easy to load rarely used plugins when you need them. You don't have to bother anymore if a plugin is disabled/archived or not."
                                You created a prototype. It uses an index file that contains a list of info.
                                This is your primiss. I did tryed your plugin and its a qood ideal.
                                There are several things your are worrying about:
                                " 1) It should be at least techinically possible to load any existing plugin that is disabled"
                                2)"But how to get the commands that should be executed, a proper name, icons, eventually keywords?" Well this is to much work for me?. I try to useing SUTool: a new way to manager your RB script but it dosn't load every thing. You have to double buffer everything "(since some plugins contain complex structures of classes and wrapper methods, not to speak of .rbs plugins)"
                                SUTool:
                                These were my ini files
                                01file.txt
                                02edit.txt
                                03toolbars.txt
                                04view.txt
                                05camera.txt
                                06draw.txt
                                07tool.txt
                                08plugins.txt
                                09context.txt
                                (Stage 1)
                                Is there a better solution? yes window/preferences_shortcuts,a dummy key, with a macro.ank, it would give API access to all commands created with UI::Command,
                                (Stage 2)
                                I will tell you how at My tips about running more than one sketchup
                                http://forums.sketchucation.com/viewtopic.php?f=79&t=40254
                                  I have a proof of concept that intercepts the creation of Command objects and make everything available. Even the procs. I hooked into menu and toolbars as well so I could traverse them in a tree structure. I was able to do a string search of the commands, much like the described concept of OP. But I haven't released it as it would need testing and a robust error handling.
                                    Aerilius
                                    I had experimented with intercepting commands, but I found it too risky for me because I don't have enough Ruby experience. When there are two scripts intercepting the same methods, it would crash SketchUp.
                                    Nice to see that this idea is becoming more common, it isn't really special. If only SketchUp made it's commands easierly accessible...
                                    http://www.markshuttleworth.com/archives/939
                                      Dan Rathbun
                                      One major problem: the menu_text is localized (or can be.)
                                      We need a ruby_text attribute that is always English.
                                      What I have been doing is attaching singleton methods for ruby_text to my individual command objects after instantiating them (to avoid changing the base class.)
                                      It would be nice if extensions, menus and toolbars has this attribute also.
                                      • halroachH Offline
                                        halroach
                                        Is this plugin still under development?
                                        The menu works very nicely, finding all the right plugins I'm looking for. But it's not working yet, is it?
                                        I've tried launchit plugin v1.4 and it just doesn't find all the plugins I have installed...
                                        eagerly waiting! 😄
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                          Aerilius
                                          LaunchUp has never been released as a finished version and it's currently paused until the SketchUp Ruby API adds the required methods (ie. not more than UI::Command.proc). There hasn't been a SketchUp major release for quite some time (over 2½ years) but is coming soon. I hope it contains finally some advances.
                                            driven
                                            hi aerilius,
                                            can Win32 get the 'menu items' by name and send 'click on name in menu' events?
                                            I've got that working fully from 'osascript and in part from 'macRuby' in 'Ruby Console' so far, but curious if there's a PC equivalent.
                                            • 2 / 2
