    [AppleScript] - Sketchup PrintRight
    75 Posts 7 Posters 7.9k Views 7 Watching
      driven
      grabbing the wrong text, here. dialogs the same on Leopard.
      I get this
        driven
        what about a simple 'on click OK', list all text items, then pick the ones you want.
        you don't need the repeater then, the final click is your next step.
          driven
          static text 1
          • jeff hammondJ Offline
            @driven said:
              "HP Photosmart C5100 series"
            lol..weird.
            do you use 'Accessibility Inspector' to help pick your targets, can be useful
            i'm trying out UI Browser.
            http://pfiddlesoft.com/uibrowser/
            seems sweet
            but i didn't realize apple had some built-in stuff for gui scripting.
            this gui stuff is kind of a pain though.. i wish sketchup would get a little applescript dictionary going..
            i wonder how hard it would be for google to implement?
            thing is, i've yet to get any of the errors you're showing on either of my machines but they both have lion on them..
            i don't know what to do about making it compatible for everyone.. ❓
              that's the problem.. applescript won't wait for OK of any of the dialog boxes other than it's own.. it's only concerned with making it's way through itself and doesn't pay attention to anything else going on.
              if i were to put an on click ok in there, it would throw up it's own dialog box which the user would also have to click on..
              ie- set your paper size then click ok in the page set up dialog.. (but clicking on anything other than the applescript dialog will bring it into focus instead.. the second 'ok' — the applescript 'ok'-- you'd have to push is now behind the sketchup window..
              no good.
                fwiw, this is a typical response about people wanting to wait for user input etc..
                Error - Page Not Found - Apple Community
                The page you tried was not found. You may have used an outdated link or may have typed the address (URL) incorrectly.
                (discussions.apple.com)
                i probably read 4 hrs worth of stuff on this issue alone and no one, even the experts, have any sort of easy solution.. it's always 'use multiple scripts' or 'don't even try it' or 'set up a timer' etc..
                but i'm new and retarded so i kept trying and found a way to do it with 3 lines..
                i posted at some other places to see why this hasn't been done before and i'm awaiting some responses.. maybe it has been tried but there's a reason i shouldn't be doing it?
                  driven
                  it works once you grab the right element, I'm surprised it's 2 on yours and 1 here, that could be a hurdle...
                  BTW. this is the 'soft start' I normally use,
                  %(#4000FF)[on run
                  try
                  tell application "System Events"
                  if (count (every process whose name is "Sketchup")) = 0 then
                  activate application "SketchUp"
                  delay 1
                  end if
                  ignoring application responses
                  tell process "SketchUp"
                  set frontmost to true
                  delay 1
                  try]
                    oh wait, i see what's going on.. phew ☀
                    i've been doing all the tests with no printer selected.. if you select a printer then a static text item will display underneath the printer popup -displaying the printer name -which makes that static text 1 and the paper size static text 2..
                    so i can just identify it in the same way i did the sketchup window # (which changes depending on how many plugin toolbars etc you have showing)
                      %(#4000FF)[on run
                      try
                      delay 1
                      end if
                      delay 1
                      try]
                      is that something i should be able to paste into applescript editor and run from there?
                      i think there are some ends or tells or something missing 😄
                      those are the things that slow me down on this stuff.. getting all of that in the right place.. it'd be a lot easier if i knew what i was doing 😄
                      • pbacotP Offline
                        Jeff,
                        Does this do anything for resolution or anti-aliasing? I find (just testing with print pdf) that exporting 2d graphic or using LO always gives an acceptable print, whereas a straight print out of SU does not. So I wonder if this scripting work of yours can be of use to me?
                        Another thought. A guy created a printing utility script for my Mac CAD program and it enabled printing of sheets (these are basically layer setups), providing a dialog to select the ones you want. It then ran prints of all those you selected. One was also able to save certain sets of print parameters, such as "save as pdf" and naming the files. Similarly perhaps you can batch print scenes in SU, which seem equivalent as both are a program-specific setup.
                        Peter
                          @pbacot said:
                          Jeff,
                          no, nothing to do with that type of stuff.. it's mainly about getting a to-scale print out of sketchup in a reasonable manner and with the drawing in sketchup looking like the print (like, if you try to print to a vertical 8.5x11 from sketchup and your drawing window is sort of widish like your screen, you'll have a wide view of the sketchup window scaled down to fit within the 8 1/2" width of the paper ... and huge borders at the top and bottom.
                          Peter
                          automator would be really good for that type of stuff and simple to set up.. it has quite a few good print options for making print plugins which are then in turn available through your print dialogs..
                          but yeah, i'm not really attempting to make a smoother workflow for sketchup, i'm trying to make a script to do something that sketchup can't do.. (well,that part is already done which is sizing the drawing window to the same aspect ratio as the paper.. i guess the rest is just sort of an assistant which will, i hope, take a lot of confusion out of sketchup's printing procedures..)
                            driven
                            static text 1 seems to stay the same regardless of what I choose in the other items... good?
                            this is wrapped and still works, the ignoring only works for menu items, so I took it out
                            on run
                            	try
                            				delay 1
                            			end if
                            					delay 1
                            					set drawwin to count of windows
                            					set AppleScript's text item delimiters to {" "}
                            					click menu item "page setup..." of menu "file" of menu bar 1
                            					repeat until focused of window drawwin = true
                            						try
                            							set psz to value of static text 1 of sheet 1 of window drawwin
                            						end try
                            					end repeat
                            					set papw to third text item of psz
                            					set paph to first text item of psz
                            					display dialog "width = " & papw & "  height = " & paph
                            				end tell
                            			end tell
                            		end tell
                            	end try
                            end run
                              yeah.. i'll just have to make sure to click on everything and try different settings in this type of situation to make sure nothing else is popping up..
                              thanks for trying this stuff out /catching the errors.
                                driven
                                you could write an applescript to do that....
                                  found a better way to get the dock info.. this will return the actual height etc..
                                  tell application "Finder" set dockOrientation to do shell script "defaults read com.apple.dock orientation" end tell tell application "System Events" to tell process "Dock" set {dockW, dockH} to size in list 1 end tell return {dockOrientation, dockW, dockH}
                                  via:
                                  http://www.snaq.net/software/applescripts.php
                                  that stuff looks way more organized than how i'm doing it.. 😄 i'm going to have to make sense of what he's doing there and copy the way he's keeping things neat it if this print script is going to be successful.. it's already starting to get messy
                                    driven
                                    Hi Jeff,
                                    although your away maybe you can try this test file.
                                    after much searching, I can get Raster images to fit an A4 sheet exactly, [pixel perfect if you drawWin to {WinWidth - 4,]
                                    I used  297 and 210 for the input dialogs on the Automator version
                                    PrintTestMac.skp
                                    now for step 2, multiple sheets, that line up.... john
                                      driven
                                      Vector quality as good as I can get at the moment
                                      PrintTestMac_eps.pdf
                                        driven
                                        Hi Jeff,
                                        just realised I hadn't added a needed ingredient, that I'm using for both raster and vector output.
                                        a ruby script.
                                        mod = Sketchup.active_model # Open model
                                        ent = mod.entities # All entities in model
                                        sel = mod.selection # Current selection
                                        view = Sketchup.active_model.active_view
                                         new_view = view.zoom_extents
                                         new_view = view.zoom 1.0525
                                        I saved it as zoomZoomed.rb and run it after Automator has sized the window, it gets rid of the margin. YMMV... john
                                        if you want it on a button for quick testing I'll knock one up, but if you run it from 'RubyCodeEditor' you can tweak the ratio setting.
                                        or did I send this... am I going mad... etc...
                                          driven
                                          and if you want to save your automator script as an app in plugin subfolder[or anywhere, just fix the path]
                                          you just call that from ruby first.
                                          system('open /Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/plugins/zZoomed_PrintRight/PrintRight.app')
                                          needs the full path for system... john
                                          I'm subtracting 4
                                          4, WinHeight} before making the app.
                                          you can still change the app in automator, just re-save and overwrite.
                                            nice.. in my experiments, i'm actually using a factor of 1.05083 after first setting the FOV to 35.00deg.. (i found the scale factor changes depending on fov so in the script, i preset to 35.00deg)
                                            i almost had this thing up and going then hit yet another wall.. all of my testing so far was using a flat plane as the drawing.. then i tried it on something with a height and everything goes out of whack so it's back to tinkering with available sketchup controls to make it happen..
                                            here's the latest for this part of the script: (copy/paste into applescript editor and run from there -- with a sketchup window open somewhere)
                                            ` tell application "SketchUp"
                                            activate
                                            tell application "System Events" to tell process "SketchUp"
                                            	--set the camera to perspective by checking if Field Of View is enabled
                                            	if enabled of menu item "Field of View" of menu 1 of menu bar item "Camera" of menu bar 1 is false then
                                            		click menu item "Perspective" of menu 1 of menu bar item "Camera" of menu bar 1
                                            	end if
                                            	--set FOV to 35 deg.. in order for the 1.05083 to work out right..
                                            	click menu item "Field of View" of menu 1 of menu bar item "Camera" of menu bar 1
                                            	keystroke "35" & return
                                            	click menu item "Zoom Extents" of menu "Camera" of menu bar 1
                                            	click menu item "Zoom" of menu "Camera" of menu bar 1
                                            	set fv to value of text field 1 of window drawwin
                                            	set FOV to ((first text item of fv) / 1.05083) as text
                                            	keystroke FOV & return
                                            	click menu item "Parallel Projection" of menu "Camera" of menu bar 1
                                            end tell
                                            end tell`
                                            with that, if you had a drawing window set to a paper size of 8.5 x 11 borderless then draw a rectangle of say 11' x 8'-6" in sketchup.. after running the script, the actual extents of the drawing would be properly zoomed then under file->Document Setup, you'll see the scale set as expected (entire paper is printed to with a scale of 1" = 1'..)
                                            i was going to use this as a basis for giving 'suggested scales' to the user that the can pick from then the model would zoom in/out in the drawing window to show exactly how it will look on the final print/pdf..
                                            anyway… i wonder if there's a way to use ruby commands in an applescript?? i might have some better control that way of the actual sketchup drawing.. i've seen a couple of examples of using python inside an applescript so i assume ruby would be possible as well?.. (and i guess the big question would be if SketchUp's ruby could be used inside an applescript which will do sketchup things instead of just using OSX's ruby)..
                                            have you ever messed around with doing anything like that?
                                            thanks
                                            • 2 / 4
