    ADDING FOREGROUND TREES
    Scheduled Pinned Locked Moved Post Processing
    8 Posts 6 Posters 9.7k Views 6 Watching
      davidh
      1.Locate an image of foreground trees - if image is coloured - colour desatutrate
      2.increase curves- (alters black and white values)
      3.copy and paste
      4.remove areas not needed
      5.blend layer with "multiply"
      Its simple.
      • irwanwrI Offline
        irwanwr
        πŸ‘
        perhaps you can say something about the application you used to edit the image?
        if i look at the screenshot, it looks like PS to me. if i am not mistaken.
        • soloS Offline
          Very cool, however can you give more detail on best way to do the last part, the removing unwanted bits, that always seems like such a hit and miss part (then again I'm using Paintshop)
          • Rich O BrienR Online
            Here's a good trick for masking trees
            Page not found | phong
            phong (www.phong.com)
            in Photoshop
            which you don't have....but need
            • Chris FullmerC Offline
              To me it looks like he changed the layer blending mode to multiply. Which would work on this image because the tree is so dark and the sky is so white.
                davidh
                Sorry,when I said remove areas not needed,I meant to crop as close as possible to the tree.It dosent matter if there is some white left but by using the multiply blend in photoshop all the white parts disappear.
                • irwanwrI Offline
                  irwanwr
                  yes, that's why he did that curve adjustment to change the contrast.
                  many ways to do that using any selection method available. also by using select color range.
                  which we can refine a bit faster with feather option.
                  πŸ‘
                    penumbradesign
                    in Photoshop
                    πŸ‘ πŸ‘ πŸ‘
