    Terrain elevation calculator
    10 Posts 4 Posters 1.2k Views 4 Watching
      tspco
      I recently have a need for a quick way to indicate the highest, and lowest points, using the origin as a fixed reference. I currently use Chris Fullmer's on screen display to do this, but it is difficult to judge the terrain to find the highest, and lowest points, while looking at it, especially when the difference is less than 20 feet.
      Any suggestions?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • sdmitchS Offline
        sdmitch
        To find the location of the highest and lowest points, you would need to look at every edge making up the terrain mesh. The only way to do this efficiently would be a plugin such as
        def label_high_low
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        hi_pt=nil;lo_pt=nil;hi=-1e9;lo=1e9
        hi_vec=[0,0,2400];lo_vec=[0,0,-2400]
        grp=sel.first;#select the GE 3D terrain
        grp.entities.each{|e|
          if e.class==Sketchup;;Edge
            (hi=e.start.position.z;hi_pt=e.start) if e.start.position.z>hi
            (lo=e.start.position.z;lo_pt=e.end) if e.start.position.z<lo
            (hi=e.end.position.z;hi_pt=e.end) if e.end.position.z>hi
            (lo=e.end.position.z;lo_pt=e.end) if e.end.position.z<lo
        ent.add_text(hi.to_s,hi_pt.position,hi_vec)#label the high point
        ent.add_text(lo.to_s,lo_pt.position,lo_vec)#label the low point
        http://sdmitch.blogspot.com/
          tspco
          So it is do-able, how hard would it be to make it work?
          This is my first look inside a "plugin" but I wouldn't have a clue what everything means.
          • sdmitchS Offline
            sdmitch
            Not hard at all. I will make it into a normal plugin that you can access from the Plugins Menu.
            Check for PM.
            • X Offline
              xrok1
              why not just make a plane at 0 copy it up with the spacing you require (say 10') then do an intersection and hide the planes. You will then see rings like a make shift topo map. You can put the edges on a seperate layer and hide/show as you please.
                tspco
                With a plugin that was made for this purpose, and a projected texture this what I get, good enough for me for now.
                  tspco
                  Here is another view, I forgot to erase some items, sorry.
                  • X Offline
                    xrok1
                    I guess i did miss the point. 😳
                    Didn't Chris make a plugin alone these lines? (min,max)
                      tspco
                      Don't know about Chris's version, sdmitch did one the other day, works as I needed it to.
                        aile009
                        > def label_high_low
                        > sel = mod.selection
                        >   end
                        > end
                        This episode code is the right thing i'm looking for. It provides an addititonal option
                        for Mesh2Heightmap. because the mesh2heightmap generate a greate heightmap but not provide
                        the minimum and maximum elevation values without which i can not use this map to generate
                        an accurate terrain.
