    [Plugin] Add Named Scene
    10 Posts 6 Posters 11.4k Views 6 Watching
      mirale999
      Hi all,I'm a newbie in ruby, although being here several years...
      I made a little plugin that lets you give a name upon adding a new scene~
      Date : v1.0 11/12/6
      Description : To Let you rename it upon adding a new scene
      Menu Item : View -> Add Named Scene
      %(#a2a2a2)[Still have a problem, I want that: when clicking the menu or hot key, give you a small inputbox, and write the name, and create, you can also not change the default name, and add the new scene as normal~ The default name of the new scene can increase each time, I made the "Scene_Num" to do it but everytime it is "scene 1".
      Who can teach me how to? 😕]
      Thanks Thomthom~! I've updated the attachment below!
      Now it works like this :
      Hit the hotkey or click the menu item, give you an inputbox, you can choose to give the new a unique name, Or leave it to its default and create like normal: Scene 1- Scene 2- Scene 3-...
      The first one define the new tab's name according to the number of existing pages:
      Named_Scene.rb
      Finally make the second one that do exactly the same thing as the normal scene tool, scene 1 - scene 2 - scene 3 - scene 4 - ... ignoring the number of existing pages, %(#BF0000)[will not have any duplicate names! 😄]
      & Use the
      File;;basename(__FILE__)
      to ignore its own file name.
      Named_Scene2.rb
      # mirale999 first release, with Thomthom's help.
      # Permission to use, copy, modify, and distribute this software for
      # any purpose and without fee is hereby granted
      # Freely use
      # Name               ;          Named_Scene.rb
      # Date               ;          v1.0 11/12/6
      # Description        ;          To Let you rename it upon adding a new scene
      # Menu Item          ;          View -> Add Named Scene
      # It works like this ;
      # Hit the hotkey or click the menu item, give you an inputbox, you can
      # choose to give the new a unique name, Or leave it to its default and
      # create like normal; Scene 1- Scene 2- Scene 3-...
      require 'sketchup.rb'
      module Named_Scene
        # Add menu items.
        unless file_loaded? File;;basename(__FILE__)
          add_separator_to_menu("View")
          UI.menu("View").add_item("Add Named Scene") { self.add_namedScene }
        @@scene_i = 1
        def self.add_namedScene
          model = Sketchup.active_model
          pages = model.pages
          # Ask user for page name.
          list = []
          prompts = ["Scene Name;"]
          defaults = ["Scene"+" "+"#{@@scene_i}" ]
          input = UI.inputbox( prompts, defaults, list, "Add Named Scene" )
          # Check if the user cancelled.
          return if input==false
          # Get data from result array
          scene_name = input
          @@scene_i = @@scene_i + 1
          status = pages.add( scene_name.to_s )
          file_loaded File;;basename(__FILE__)
      Hi all, after several years this small plugin has a bug because of the new version of ruby, and mariocha adds LanguageHandler in this version.The new modified version is here:
      Named_Scene2.rbz
      paranoia is a higher form of awareness...
        ` 'Scene1'.next
        Scene2`
          Ah - looking at your code now:
          <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;mirale999&nbsp;first&nbsp;release<br />#&nbsp;Permission&nbsp;to&nbsp;use,&nbsp;copy,&nbsp;modify,&nbsp;and&nbsp;distribute&nbsp;this&nbsp;software&nbsp;for&nbsp;<br />#&nbsp;any&nbsp;purpose&nbsp;and&nbsp;without&nbsp;fee&nbsp;is&nbsp;hereby&nbsp;granted<br />#&nbsp;Freely&nbsp;use<br />#&nbsp;Name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Named_Scene.rb<br />#&nbsp;Date&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;v1.0&nbsp;11/12/6<br />#&nbsp;Description&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;To&nbsp;Let&nbsp;you&nbsp;rename&nbsp;it&nbsp;upon&nbsp;adding&nbsp;a&nbsp;new&nbsp;scene<br />#&nbsp;Menu&nbsp;Item&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;View&nbsp;->&nbsp;Add&nbsp;Named&nbsp;Scene<br />#----------------------------------------------------------------------------<br /><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'sketchup.rb'<br />&nbsp;<br /></span><span class="syntaxdefault">Scene_Num</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br /><br /><br />module&nbsp;Named_Scene<br />&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unless&nbsp;file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">'Named_Scene.rb'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Add&nbsp;menu&nbsp;items.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">add_separator_to_menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"View"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"View"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Add&nbsp;Named&nbsp;Scene"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">Add_NamedScene&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">Add_NamedScene<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;pages&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pages<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Ask&nbsp;user&nbsp;for&nbsp;page&nbsp;name.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">list=[]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">prompts</span><span class="syntaxkeyword">=[</span><span class="syntaxstring">"Scene&nbsp;Name;"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">defaults</span><span class="syntaxkeyword">=[(</span><span class="syntaxstring">"Scene"</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">Scene_Num</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">)&nbsp;]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">input</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inputbox</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">prompts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">defaults</span><span class="syntaxkeyword">,&nbsp;list,&nbsp;</span><span class="syntaxstring">"Add&nbsp;Named&nbsp;Scene"&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Check&nbsp;if&nbsp;the&nbsp;user&nbsp;cancelled.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;if&nbsp;</span><span class="syntaxdefault">input</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">false<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Get&nbsp;data&nbsp;from&nbsp;result&nbsp;array<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">scene_name&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">input<br /><br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;status&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pages</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add&nbsp;scene_name</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Scene_Num</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Scene_Num&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">1<br />end<br /><br /></span><span class="syntaxcomment">#-----------------------------------------------------------------------------<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Named_Scene.rb'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxcomment">#-----------------------------------------------------------------------------<br />&nbsp;</span><span class="syntaxdefault"></span>
          Your Scene is a constant. But you are using it as a variable.
          You need to look into the difference between variables and constants. Initial capital letter means a constant in Ruby.
          Here's an amended version:
          <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;mirale999&nbsp;first&nbsp;release<br />#&nbsp;Permission&nbsp;to&nbsp;use,&nbsp;copy,&nbsp;modify,&nbsp;and&nbsp;distribute&nbsp;this&nbsp;software&nbsp;for&nbsp;<br />#&nbsp;any&nbsp;purpose&nbsp;and&nbsp;without&nbsp;fee&nbsp;is&nbsp;hereby&nbsp;granted<br />#&nbsp;Freely&nbsp;use<br />#&nbsp;Name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Named_Scene.rb<br />#&nbsp;Date&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;v1.0&nbsp;11/12/6<br />#&nbsp;Description&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;To&nbsp;Let&nbsp;you&nbsp;rename&nbsp;it&nbsp;upon&nbsp;adding&nbsp;a&nbsp;new&nbsp;scene<br />#&nbsp;Menu&nbsp;Item&nbsp;&nbsp;&nbsp;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;View&nbsp;->&nbsp;Add&nbsp;Named&nbsp;Scene<br />#----------------------------------------------------------------------------<br /><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'sketchup.rb'<br /><br /><br /></span><span class="syntaxdefault">module&nbsp;Named_Scene<br />&nbsp;<br />&nbsp;&nbsp;unless&nbsp;file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">'Named_Scene.rb'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Add&nbsp;menu&nbsp;items.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">add_separator_to_menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"View"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"View"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Add&nbsp;Named&nbsp;Scene"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_namedScene&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /><br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_namedScene<br />&nbsp;&nbsp;&nbsp;&nbsp;model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;pages&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pages<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Ask&nbsp;user&nbsp;for&nbsp;page&nbsp;name.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">list&nbsp;=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">prompts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxstring">"Scene&nbsp;Name;"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">defaults&nbsp;</span><span class="syntaxkeyword">=&nbsp;[(</span><span class="syntaxstring">"Scene#{pages.count}"</span><span class="syntaxkeyword">)&nbsp;]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">input&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inputbox</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">prompts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">defaults</span><span class="syntaxkeyword">,&nbsp;list,&nbsp;</span><span class="syntaxstring">"Add&nbsp;Named&nbsp;Scene"&nbsp;</span><span class="syntaxkeyword">)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Check&nbsp;if&nbsp;the&nbsp;user&nbsp;cancelled.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;if&nbsp;</span><span class="syntaxdefault">input</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">false<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Get&nbsp;data&nbsp;from&nbsp;result&nbsp;array<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">scene_name&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">input<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;status&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pages</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">scene_name&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;<br />end<br /><br /></span><span class="syntaxcomment">#-----------------------------------------------------------------------------<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Named_Scene.rb'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxcomment">#-----------------------------------------------------------------------------<br />&nbsp;</span><span class="syntaxdefault"></span>
          I make the default name of the scene be made out of the number of existing pages in the current model. If you do it your way, with instance variables instead of constants, then it would just keep on counting between models.
          I also cleaned up your indentation. Always keep your source code clean and organized, good indentation makes it easier to read - which is essential to debug and maintain your code.
            mirale999
            Thanks Thomas~!! I use your code and now it's a correct version!
            And the Scene name is the very same as the normal one~
              But.... if you delete a scene or two you'll end up with duplicate names. So if you want to avoid that, then you need to make some extra checks.
                mirale999
                Done!
                • mariochaM
                  mariocha
                  Hum.. This plugin is a very good idea. Often wished this would be the native way to do.
                  But for me it the bracket and quote signs are unwanted?
                  See scene 555 attached.
                  %(#008000)[Mario C.
                  • G
                    glro
                    this is because the plugin has been written with a previous version of ruby
                    instead of
                    scene_name = input
                    put
                    scene_name = input[0]
                    • C
                      chrisconcise
                      Good Job on your plugin, We are often creating scenes, and it is a pain to not be able name it once created. When creating a scene, the scene name it add includes [""], It would be really helpful to me if it could be modified, so that the scene name is only what you enter into the field, maybe I am doing something wrong, please advise if you would
                      thanks
                        ramonbastos
                        thanks
                        I need exactly this.
