    Seamless Snowy Trees
    8 Posts 7 Posters 2.3k Views 7 Watching
    • Alan FraserA Offline
      Alan Fraser
      Just in time for Christmas; here's a NPR version of some winter trees I'm preparing. This is as seamless line of snow-covered fir trees. Import and stretch it as long as you like for a background pano.
      3D Figures
        Thanks Alan, they really look good as a background. I applied it on a curved treeline that always faces the camera. πŸ˜„
        • EscapeArtistE Offline
          EscapeArtist
          Well done. Thank you for sharing.
          • Mike LuceyM Offline
            Mike Lucey
            Thanks Alan, but I hope we don't get snow this Christmas πŸ˜’
              RichardCherry
              Those are gorgeous. Thank you so much πŸ˜„
              • W Offline
                wyatt
                Great image. Thanks!
                • simon le bonS Offline
                  simon le bon
                  Great πŸ‘ πŸ‘
                  Thank you Alan
                  ++Simon
                    Alan Fraser
                    By way of information; I have found that there is quite a demand for this type of NPR image. Standard Imagecels stuff is fine if you are going for a photoreal effect, but just doesn't sit happily with native SU image export...or with many of the styles.
                    I used to use a brilliant Photoshop simplifier plugin called Buzz Pro to do this kind of stuff, but the company (Fo2pix) went out of business...although if you search hard enough, you might find some 'orphaned' copies floating about on the Net.
                    Topaz Labs took up the torch and now produce a filter called Topaz Simplify, which has a Buzz 'tribute' setting, producing much the same kind of effects. It will not only produce the kind of simplified image, like the trees, which blends well with SU's minimalist 'illustrative' look...but it can also produce effects that can turn all your existing photographic Face Me components into something that can blend in with just about every style that SU can produce.
                    Topaz Simplify Link
                    http://www.topazlabs.com/simplify/_images/transformer_lg.jpg
                    3D Figures
