    Extension manager hooks?
    8 Posts 5 Posters 540 Views 5 Watching
      avariant
      The release notes for M2 state this:
      "Ruby plugin hooks: In addition to the above functionality, we have added several API hooks to allow Developers to more easily write their own Ruby extension managers."
      I haven't been able to find any info about this on the sketchup blogs, here at sketchucation, the API docs, or anywhere. Does anyone know what this new functionality is?
        driven
        basically, if you zip your my.rb and rename it my.rbz, SU Extension Manager will load it from your 'download destination' directly into 'Plugins', saving your Users all the grief of what do I put where.
        and some other bits...
          avariant
          The release docs list the zip stuff separately from the "API hooks". And the zip integration wouldn't be have anything to do with the API anyway. I think they must be talking about something different, at least it certainly sounds like it to me.
            driven
            they had to rewrite a bit of the API and authors have write/re-write their scripts via the API to use those 'new' hooks effectively, but there is other stuff coming, I'm sure... john
              The .rbz file format can be 'auto-installed' via Preferences even it it's NOT an 'Extension'...
              I already asked Google to rephrase the wording on that button... but to no avail...
              This means that any script packaged as a .rbz format file can be [relatively] painlessly installed using that button using the Preferences option [in an appropriate v8+++]... however, those that are made as proper 'Extensions' offer the user the ability to switch the tools on and off via Preferences...
                avariant
                But this isn't new, right? This has been available for a long time...
                  Jim
                  Sketchup.install_from_archive("C;/Folder/Plugin.[rbz|zip]") # unzips an .rbz or .zip archive to the Plugins folder.
                  Skethcup.plugins_disabled=(true|false) # enable/disable loading of the Plugins folder on next start.
                  Skethcup.plugins_disabled?
                  Sketchup.extensions #- returns the list of SketchupExtension objects
                  Sketchup.extensions[name_or_index]
                  Sketchup.extensions.methods
                  ["select", "partition", "grep", "reject", "member?", "find", "each_with_index", "collect", "all?", "length", "entries", "detect", "zip", "map", "any?", "size", "sort", "count", "min", "find_all", "each", "inject", "keys", "sort_by", "max", "[]"]
                  SketchupExtension.new.methods - Object.methods
                  ["description=", "copyright", "copyright=", "loaded?", "version", "version=", "check", "load_on_start?", "load", "name=", "registered?", "register_from_sketchup", "creator", "uncheck", "creator=", "unload", "description"]
                  My understanding is that at least some of the SketchupExtension instance methods are meant to be called by SketchUp rather than by plugins.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    Yep.
                    If interested, just read comments in the new extensions.rb file in the Tools dir.
                    I'm not here much anymore.
